Pallete?
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Pallete?
    Default Pallete?
    Just wondering what you guys use for palletes?
    Plastic chinese takeaway lids! lol
    A cheap plastic pallette that I can get from an art store around here.
    personally I use a clinker square... but I have heard that it\'s quite nice to use akuminum foil :) hope that helps ;P
    // Larre
    Arkzein
    Likewise, think they\'re a pound or two, just toss one when it gets tired.
    Also have to say my thumbnail gets a fair bit of use. ;)
    pink tupperware wet pallete :rolleyes:
    tiles there easy to clean after only problem is when i use it my paints dry very quickly unless that just becouse its games workshop paints
  9. #9
    Ditto.
  10. #10
    I went to the hardware store and picked up a nice white, glazed ceramic tile that is about 4x6 for less than a buck and it works great. You have plenty of room to mix on, and if it gets too gunked up you can takea razr blade o it and it\'s good as new. The white also lets you see your colors well and, as long as you don\'t drop it, it\'s quite durable.
  11. #11
    Superfreak!!! Sand Rat's Avatar
    May 2002
    Austin Texas
    Posts
    6,818
    Blog Entries
    19
    24
    El Cheapo plastic pallette from Michals or Hobby Lobby - bout a buck I think.
  12. #12
    elouchard
    aluminum foil
  13. #13
    I mix paint on a ceramic tile or Perspex, using a painting knife mostly (I don\'t use hobby paints so mine are much thicker usually).
    Then I transfer to a homemade stay-wet palette.
  14. #14
    Apr 2002
    Posts
    17,305
    38
    A white ceramic tile.
    But I also have several \"recessed well\" pallettes for very fluid wash mixes. They do have a tendancy to save my denims from a multi-coloured bath now and again.
    Never used a wet-pallette, but then again I can\'t wet blend.
  15. #15
    I have a plastic pallete i got from an art store and also the lids off butter tubs.
  16. #16
    CD-Roms.
    My Dad had the habit to collect CD-Roms he doesn\'t need - AOL giveaways, failed burns, the CD\'s that come with magazines, ... giving me a virtually endless supply.
  17. #17
    Cheapo waxy coated paper catering plates. No need to wash, just chuck them when the dried paint is too mountainous to use any longer :D
  18. #18
    if you use a tile, pore boiling kettle water on the tile it loosens the paint then oyu can just scrape of with rough side of sponge
  19. #19
    Broken bathroom tile (White)
  20. #20
    A 12 well porcelain palette at home and a 7 well flower palette on the road. Both clean up fairly well and keep the paint where it should be.
    That said, a ceramic tile works fairly well too, though the paints dry out faster.
