Strange place to ask - need some urgent Excel help (read post)
Results 1 to 7 of 7
Thread: Strange place to ask - need some urgent Excel help (read post)
    Default Strange place to ask - need some urgent Excel help (read post)
    Hello,
    @ work rite now, so can't register @ a s/w forum (can't get the confirmation emails to activate accts), etc. So this place was first choice 2 try and ask.
    need some excel help.
    I have tables as below and need the merge example below.
    List 1
    a
    b
    c
    table 1
    x t
    y u
    z v
    What I need is final output:
    Table Merged
    a x t
    a y u
    a z v
    b x t
    b y u
    b z v
    c x t
    c y u
    c z v
    Is there a function to automatically select the 2 input tables and make it output the merged?
    I can't find a function to do it, or a formula (atleast, can't think of it right now if there is one).
    Also, i don't know Visual Basic to write a program to do it
    Any help would be appreciated.
    Regards,
    Sanjay
    Yeah, I can't think of anything right off hand (even tried in excel). And I'm assuming that the letters represent actual numbers.
    You could try a vlookup perhaps, but that may be more effort than just making a giant copy/paste of equations pointing to the correct cells.
    "Reality, she's a mathematical bitch from hell.", MaxedOutMama
    Wanna be bored? Watch me twitter. --<>-- Still have neurons? Watch my YouTube channel on painting!
    Want to know when to fry your neurons? My painting twitter will announce the videos.
    To judge how far to follow my advice, consider this: ---<>--- Slappin' paint on minis since 2006
    Would a pivot do the trick?
    Brushlicker noneedforaname's Avatar
    Jul 2006
    I live down in Dorset with the cider and the combine harvesters yaargh!
    Posts
    1,332
    15
    Are you adding or multiplying the figures from the two columns if so that's pretty easy and can probably tell you how (if I can make my brain work) so what is it your after?
    No, i need to put the data into that new table format, so later i can do a 1 to 1 vlookup (to compare tables).
    Sanjay
    Ok, it is a strange place to ask and even stranger that I have noticed it. If you dropped it on one of Excel forums you would get your code much sooner. So, what you see below is a code that does what you asked in your in your original posting before you edited it. Sorry, I saw this post in the morning and I got around to write it only now. It is not very elegant but it does the job. PM me if you need help using it.
    __________________________________________________ __________________________________________________ ________________________________________
    Sub reformating()
    'reformats table ' it is assumed that original table
    'a x t ' is in columns A,B,C
    'b y u ' Place cursor into column D
    'c z v ' Your output will be in columns E,G,F
    ' to the format bellow
    'a x t
    'a y u
    'a z v
    'b x t
    'b y u
    'b z v
    'c x t
    'c y u
    'c z v
    nA1 = Range("A1", Range("A1").End(xlDown)).Count ' determines the # of rows
    bp = 1
    For X = 1 To nA1 * nA1
    ActiveCell.Offset(X - 1, 1) = Cells(bp, 1)
    ActiveCell.Offset(X - 1, 2) = Cells((X - nA1 * (bp - 1)), 2)
    ActiveCell.Offset(X - 1, 3) = Cells((X - nA1 * (bp - 1)), 3)
    If Int(X / nA1) = X / nA1 Then
    bp = bp + 1
    End If
    Next
    End Sub
    HI there
    You can free to decide to
    merge Excel documents into a single one, and then save the combined Excel file to memory stream with following C# demo code. /// <summary>
    /// Combine a list of Excel document into a single one and save it to stream
    /// </summary>
    /// <param name="s"></param>
    /// <param name="docList"></param>
    public void CombineDocumentsToStream(MemoryStream s, List<BaseDocument> docList)
    XLSXDocument.Combine(docList, s);
