Results 1 to 8 of 8
Thread: How do you stop superglue drying out?
    Default How do you stop superglue drying out?
    I have a pot of superglue. It is still half full but the glue has started to go much more tacky than when I first bought it and I know from previous pots that it will eventually totally solidify, leaving me with half a pot of useless rubbish. Am I the only one who is afflicted by this problem and does anyone have any idea how to prevent it?
    I don't bother with it at home, but at work we keep our glues in the refrigerator. Also, always make sure the tip is cleaned out and top on tight. Sometimes the glue just gets old though.
    Quote Originally Posted by StillLifeMiniatures View Post
    Surgical glue?
    The stuff drying out in the tube is why I don't use superglue anymore.
    I do wonder if you were to keep the tube of glue submerged in a cup of water would stop the drying. Or would the water react with the superglue?
    Surrealism: You have two giraffes. The government requires you to take harmonica lessons.
    Quote Originally Posted by Shawn R. L. View Post
    Yup, it reacts with water. Could always try putting it in a good jar with some silica gel. But probably going too far with that. I just try to buy small bottles and tighten well.
    "Reality, she's a mathematical bitch from hell.", MaxedOutMama
    Wanna be bored? Watch me twitter. --<>-- Still have neurons? Watch my YouTube channel on painting!
    Want to know when to fry your neurons? My painting twitter will announce the videos.
    To judge how far to follow my advice, consider this: ---<>--- Slappin' paint on minis since 2006
    Gelified superglue seems not to dry that easily, I've been using the same tube for more than a year. When needing liquid superglue, I'll buy the smallest tube I can find, and make sure to close it as best as I can.
    Common problem this; I'm guessing that most superglue is lost to this, rather than actually being used to glue stuff together.
    Tip cleanliness etc. will only take you so far IME, other than getting lucky with tubes that have a good natural seal (bought some super-cheap stuff recently that beats the pants off Loctite!) the only solution I've found is to seal around the cap with Parafilm-M. I suppose Teflon tape could work in a similar way, but I don't know if that's cost-effective.
    Posted this and other superglue tips previously in a handy little hints thread.
    Jan 2003
    sunny orlando
    Posts
    7,634
    23
    Shawn, water is what makes superglue set off.
    It is the humidity that makes the opened tube go bad.
    Solutions:
    1. Buy smaller tubes.
    2. Keep the tube somewhere with lower humidity.
    3. Seal the tube better.
    p.s. The model guys producing a movie that was partially shot in Greenland. They could not alter or repair their models in the field as there was not humidity in the sub-zero cold to make the superglue set off. They had to go indoors and spray water on the glue joints to get them to set.
    My Favorites
    I'm at and falling.
    si vis pacem, para bellum
