Secret Mission Title font
Results 1 to 13 of 13
Thread: Secret Mission Title font
    Default Secret Mission Title font
    Hello
    I would like to know which font is used for the secret mission cards title ?
    I tried to use Tom Hill editor, but I would like to translate the cards in french, and it does'nt work.
    Thank for your help.
    If you download the editor the readme file or the how to document that came with it. He lists all the fonts.
    ~Lieutenant Nathaniel Flint of the Landship Scorpios
    Your problem is the font doesn't have certain characters. If you managed to find a version that does please let me know.
    Sorry it's a limitation at the moment until ai get time to create the missing letters.
    Rivet Wars Scenario Editor - http://www.tehill.net/RivetWars
    Hello
    After many hours of research, I finally decide to use the TREMBLE font (free). It's not exactly the same, but it's better than nothing.
    Thank.
    Thanks for letting me know, btw - do you have the French Edition of the game?
    I'd be interested in knowing if the same font was used - a photograph of some of the card would be really helpful; I should be able to track down a correctly formatted font. Sorry it's been a pain for you.
    Hello
    I have the french edition of the game. I try to translate the cards designed by the community.
    For me, the fonts used in the french version are the same as these used in the english version.
    Here is a example of a action card :
    Thanks for this, I'm having a look now at manually creating the missing characters in the fonts. I'll keep you posted.
    This is my test string: àâäèéêëîïôœùûüÿç
    Here's the output for Action Cards - the font used for quotes is really strange, I've not figured out how to open it yet.
    Here's the output for Secret Mission Cards -
    So plenty of characters are missing -
    I've made the first set of modifications to the font:
    I'll start on the description font now.
    I'm guessing you can live without a dipthong? At least until the Rivet Wars Mediæval expansion comes out
  9. #9
    Completed the second font here:
    Still not sure what's happening with the 'quote font' - Think I need to make the Cedilla slightly larger on both fonts.
    Let me know how you get on.
  10. #10
    Hello
    I have made a rapid test with a secret mission card. For me, it's works very well. As you say, cedilla could be a bit larger, but it's not very imporant. It's clearly readable.
    I have a little question : is-it possible to change the size of title font ? Because french language is not as concise as enlish language. I need more words (and more space) to translate.
    For the moment, I get around this problem with Photoshop Element.
    Thank you for your help and the great work you do !
  11. #11
    Thanks for the feedback, I had another go at the cedilla and I've added a title font size box on the card page. I should probably work out how to size the font to fit the card, but this should be enough for now.
    The default value is 35. Here's an example with it set to 20:
  12. #12
    Hello
    I have tried. It's works perfectly.
    I think I'm a bit exasperating, but, alaways for the same reasons, is-it possiblefor you to add a victory line font size box ? French words are definitively too long !
    Here is a one of your card translated :
    Many thank for your great work and your patience.
  13. #13
    Wow, this looks really good! The new characters look great!
    I've added 2 new font sizes to the description and the victory lines.
    Hopefully these will help you!
    Just a note: the description font size does adjust if there are 1-3 lines of text. But it's the initial value you can set; it will be slightly larger if there's only 2 lines.
    Great Work
