Solo play offline issue
Results 1 to 2 of 2
Thread: Solo play offline issue
    Default Solo play offline issue
    So tried the latest build again on the way home from work on iPad Air 2 while offline which is how I have mainly found time to test, but on this occasion the game wouldn't play while I was offline at all in solo play.
    i tried solo with all the divisions and various difficulty settings, but nothing worked, after it loaded it sat on the image screen and never clicked over to the cards.
    i then tested the tutorial which worked while offline, then when I had wifi access available tested the solo play mode which worked immediately
    now after it having connected to the network it works offline ok?
    Just released build 23 that should fix this!
