ADE goes giant mad... - Page 3
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 41 to 60 of 231
Thread: ADE goes giant mad...
  1. #41
    Loving the work you have done on these minis. That hippo is looking great.
  2. #42
    Starting to get a bit of shape into the Reaper Hill Giant.
  3. #43
    Started a couple more projects this week,a Dungeons and Dragons Frost Giant and a Harry Potter Mountain Troll. The Troll stands 8 inches when complete, it was broken down into it's separate components and then rebuilt using Araldite. The cavities were filled with Ronseal wood filler which sets like concrete in a few minutes,any over spill on the joints was sanded flat with wet and dry paper.The join line around the torso and the mould line around the arms were worked with a small diamond file and scalpel then burnished with steel wool to soften the effect and to blend in with the existing skin texture.The joints were drilled out with a Dremel to get a nice snug fit.
  4. #44
    Two sub assemblies finished just needing a bit of filling in a couple of places,the legs were glued and screwed on and then this is glued and screwed to the torso.
  5. #45
    Picked up a wooden base from Hobbycraft for £2 which was filled,sanded and then the edge was burnished with wire wool to get a super smooth finish.The Troll was glued and screwed to this.The hands were a nightmare to prep as the mould line went all between the fingers.The club is just a piece of old wood which was worked with a Dremel to give a little more character, this was then fitted into the hand by forcing the fingers open,once in place the hand was put in boiling water for 3 minutes and clamped over night to give a nice tight grip around the club.Filling work was then completed on the main assembly leaving just the hands and head to attach then blend in.I've include a near finished pic but the hands and head are just pressed on at this stage.
  6. #46
    With the exception of the filling and completion of groundwork the Troll is now finished.The slate on the base has started to be blended in with Magic sculpt also there are some extra creatures on the base, a frog,rat and goblin.The hand was drilled in two places and brass rod glued in to hold the club in place then super glue was run all around the inside .
  7. #47
    Troll construction now finished.Head and neck blended and textured with Magic sculpt then the whole figure painted with liquid green stuff to unify the surface on all the areas that had been worked on .The base was covered with PVA then sprinkled with five different sizes of small stones,gravel and sand.Once this was banged to knock off the excess a runny mix of PVA,water and a few drops of washing up liquid(to break surface tension) was applied with a pipette to firmly hold everything in place.
  8. #48
    Troll now primed with Vallejo black surface primer from an airbrush.
  9. #49
    This is a really cool construct...love seeing how you are bringing it back to life.
    BUT, he better see a DR about that water retention issue with his legs...wouldn't want to amputate! Lol
  10. #50
    Got a good amount of painting done on the first day,using grey mixed with Windowlene to allow better flow through my airbrush,then blocking in some other areas with a brush.Got a bit of shape into the club and stump too.Leave now to harden for a day and next will be a wash of the skin and other areas using enamel to allow better control with the extended drying time.You're right about his legs Krule, they are monstrous but probably great for a bit of human crushing.
  11. #51
    Decided to use acrylic with a slow dry gel to do the shadows on the Troll, it's a massive figure to handle and progress is slow.
  12. #52
    Only a little more forward with the Troll, extra highlighting on skin,club and stump,eyes started and skulls and ropes on his animal skin.
  13. #53
    More skin highlighting on the Troll plus washed some purple and red into the knees and elbows to add some more interest to these areas.Cracked into the base in a very rough way and will now start to bring this up with some subtle washes and dry brushing.
  14. #54
    The troll is looking great. I really like the pallet you have gone for. Good stuff.
  15. #55
    Nearly finished all the work on the base today which is another monster amount of detail to sort but now almost there.Bringing in all the little details and liking the way the troll and base are looking as a whole piece.The toad and snotling aren't quite finished .....but not long now.
  16. #56
    I’ve been following this one through, and feel bad that I haven’t commented more, but I haven’t really known what to say as you’re tackling this in a way I’m not used to.
    He’s looking superb though. I’d like to see the contrast in the legs extended to the rest of the skin. Awesome work though
  17. #57
    Troll is done except from some work on the upper body.The biggest problem with working on this model was handling such a large figure.It was inevitable that damage would occur no matter how carefully it was handled and loss of paint was a huge problem with the torso and arms.With this in mind it was given a coat of matt varnish to seal in the work at this stage and now hopefully the remaining highlights can be applied in one session before a final varnish.
  18. #58
    Troll finished,given a coat of Klear through an airbrush.This provides a tough protective gloss coat then 24 hours later Matt varnish sprayed on.It's hard to get an accurate representation from the camera and in places the brushstrokes can seem extreme but when it's in front of you it all makes sense.
  19. #59
    The additions of the little critters add some cool aditional interest. Congrats on completing him.
  20. #60
    The Lindberg T-Rex, cheap as chips and easy to find,this styrene kit still makes a great piece though.
