Charge question - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 43
Thread: Charge question
  1. #21
    Read his full quote about this subject here:
    ""A unit may never end a move within 1" of an enemy unit unless that move would bring it into contact with the target of its charge".
    That is the full quote of the rule, it makes no reference to specific enemy units at all- saying otherwise is extrapolating rules that don't exist. If the move itself brings you into contact with the target of the charge, it doesn't care at all who you are within 1" of.
    Otherwise, you could almost never charge if two enemies were next to each other, and actually never charge an enemy between two others."
  2. #22
    Quote Originally Posted by TheRedGod View Post
    Yes but you can't have more then 2 units on 1 side of you. So the charge is legal, BUT how the picture is is illegal.
    To legalise this, he had to take a more left or right so only 2 touch him
  3. #23
    Okay, we still disagree on this then. I also originally read that rule quote like that (and I thought that rule quote is clearly and explicitly allowing becoming engaged with multiple enemies, as long as you only resolve charge against one enemy), but the only direct answer to that question has been this one here in the forums: "(consequently) you cannot engage more than one enemy at once.""
    It would seem that one more rule clarification in this subject is still required from official source, if you think that that answer from Neo [CMON] is not explicitly forbidding becoming engaged with more than one enemy at once.
  4. #24
    You know what can actually fix this? Engagement tokens (for people who ever have played Battles of Westeros)
    Use 2 versions of them, 1 that has 100% on it and the other that has 50% on it (or make them double sided)
    Make them big enough that you can put it on both the bases of the units that are engaged. In this way, you know which ones are engaged and which ones have to declare a charge in order to engage them.
    Also, in case of the beserkers charging the mountain, you can then put an 100% token on them so the others can't charge unless they spend a turn (or maneuver zone) maneuvering so they are in the flanks. Or the mountain must attack and change it to 50%
  5. #25
    Quote Originally Posted by JeppeP View Post
    You're engaged if you are in contact. I'm not seeing a need for a token to tell me that we're touching, that should be pretty obvious.
  6. #26
    This mechanic (of being in contact but not engaged) is not mentioned at all in the asoiaf rule book, so this mechanic does not help here when asking about asoiaf rules, if playing with official rules.
  7. #27
    You are responding on a thread that has 1 unit charging another unit but because of this he is in base contact with 3.
    • Align with Enemy: When a unit makes a Successful Charge,the attacker will then align with the targeted enemy unit. Theattacker’s tray is placed so that it is either aligned center-tocenterwith the target’s tray or 50% aligned (as to allow anotherfriendly unit to later engage that enemy) on the target’s Line ofSight Arc previously determined.
    So If the beserkers choose to engage 100% with the mountain, then no one else can engage them from the front.
    I hope this is clear?
    The only way to engage someone is if you charge them or be charged by them.
    This is the main reason why we got rid of the auto fail charge on the roll of a 1. Which is now disorderly
  8. #28
    I do apologize, if center-to-center is the arrow, then indeed my first comment was wrong, and there is indeed no need for those tokens
    BUT
    you must remember that if the beserkers did choose to 50% the mountain, that the other unit still has to charge them even do they would automatically make it (so roll for disorderly)
    And also, because they are now 100% alligned with the mountain, the others can't charge or attack the beserkers
  9. #29
    Heres what we know, and why I think the original post is legal.
    You ignore the 1 inch rule when charging successfully
    You can ONLY be engaged if you are the one charging OR are the target of a charge.
    Thus, the other two units in the picture are NOT engaged, therefore not breaking any engagement rules.
    Legal Charge.
  10. #30
    I do have my own tokens when playing for situations like this. If the Berserkers aligned 50% it would be hard to tell.
  11. #31
    Fronx, read the quote above from Michael, everything is him except the first line. He specifically calls out this situation...
  12. #32
    What i meant with not needing those tokens was for real game purposes, but for reminders they are handy
  13. #33
    To formulate above spam into a form of a questions that can be officially answered:
    1. Is there any way that a Charge action could bring more than two non-friendly Units in to a (non-corner) tray-to-tray contact with each other as a result?
    2. Can an Unit have a tray-to-tray contact with enemy unit so those Units would not be engaged?
    (e.g. if corner touches enemy unit tray side, that is not an engagement? Any other way to be in touch without being engaged?)
    3. If only way to Charge an enemy Unit would be to become into a (non-corner) tray-to-tray contact with another, non-target enemy along with the target enemy (as a part of the aligning move), is that Charge then illegal and cannot be done?
  14. #34
    Legal Charge.
    I agree. Legal charge.
    All other units are considered UNENGAGED except for berserkers and the mountain. Even if they are touching.
  15. #35
    to the original question, third paragraph
    "when a unit performs a charge action, it must declare a valid target for its charge, the following must apply"
    The LoS Arc of the target unit must have space for the
    attacker’s tray to fit (see Determine Line of Sight Arc, below).
    Meaning that if there is another unit engaged center-to-center
    in the same LoS Arc, it is preventing the charge (see Align with
    Enemy, below). Note that this also means that a unit can never
    have more than 2 enemy units engaging it from the same side
    (Front/Flank/Rear).
    by what i read is that the charge against the mountain is successful, but must shift over to engage only 2 units.
  16. #36
    I think what's happened here (and in some of these other threads) is that we've identified some outlier situations that are not covered under the scope of normal rules or normal situations. These are EXCEPTIONS to the rules. And therefore, I suspect some or all of these threads will not be able to be explained by referring to the rules, because....well, the rules don't cover this. We will likely need to wait for Rulebook 2.0 to cover these things.
  17. #37
    Quote Originally Posted by Fronx View Post
    Oh boy would it be nice to get an official answer to this.
    In this tournament, judge made an error:
    https://www.youtube.com/watch?v=3cDW...outu.be&t=1425
    This would be exact case of this, which is answered by Michael Shinall:
    http://www.coolminiornot.com/forums/...eping-distance
    That exact move in the video should have been legal (the first attempt), at least as there a corner touches a tray side. But, here it is being said by Neo from CMON that engagement (which in rule book is same as tray-to-tray connection) can only happen between the attacker and defender, no other units allowed:
    http://www.coolminiornot.com/forums/...l=1#post872536
    So still no clarity, while tournaments are going on and these issues are being faced.
  18. #38
    1. As they are written, nothing is preventing you from contacting multiple enemies during a charge, as long as the following criteria were met: 1. You didn't contact someone that wasn't your target while you were moving 2. you successfully completed your charge (which means you didn't do 1). Basically, if two enemy units were touching side-by-side and I successfully charged 1 of them, and wanted to align 50%, the question is what happens to the other enemy unit? Don't have an answer for that as nothing I've found in the written rules really covers this specific scenario.
    2. This has a 100% definite answer: The rulebook defines "engaged" as being in contact with an enemy. Period. if you're touching, you're engaged. This isn't up for argument by the written rules.
    3. Again, as the rules are written, your charge was 100% legal, but as I said, I cannot find anything covering how to handle the other enemy.
  19. #39
    Quote Originally Posted by Alliser Thorne View Post
    I'm starting no notice a pattern (from previous messages on this forum and on other sources), that if Allister makes a comment on how to interpret the game rules, it is very likely correct ruling as intended by designer (even when there might be room for interpretations due to certain wordings on the rule book, especially if reader is not native English speaker and/or accustomed to miniature tabletop game rules).
    But in this question, if even he says he is not sure what happens in this Charge situation, I worry that this is definitely un-answered question and could use an official clarification
  20. #40
    Necroing old thread:
    while there now is FAQ entry stating, that Charge can cause multiple engagements, it is still unclear could 3 units be in same side, as in the start image of this thread, assuming the stark unit made the charge. Even though it is rare, it can happen in a game (especially with multiple monster trays).
    RAW says "only 2 on side" still on page , so I'm inclined to presume that still is a rule that needs to be obeyed, even though FAQ states that Charge can cause multiple units to be engaged:
    I would normally consider this legal, but there is following note in the rule book page 18:
    (Front/Flank/Rear).
    FAQ:
    Q: Can I end a Charge action engaged with multiple enemies? If so, what happens?
    A: Yes. Although rare, after all alignment is completed from a successful Charge, the attacker may find its tray touching additional enemies. In such an event, the units are engaged. The attacker can still only resolve its attack against the original target, and the additional contacted enemies are not forcibly moved in any way as a result of that Charge move.
Tags for this Thread
