Does suffering hits or wounds outside of an attack action cause a panic test?
Results 1 to 8 of 8
Thread: Does suffering hits or wounds outside of an attack action cause a panic test?
    Default Does suffering hits or wounds outside of an attack action cause a panic test?
    So this came up the other day in a game.
    Scenario: A tactics card is played that states 'causes d3' wounds' (eg Roose Boltons - Calculated Cruelty). All the triggers are met and it is not an attack action.
    Do the wounds suffered cause a panic (or morale) test?
    We were not completely certain on this. I foresee two options.
    1. The rules are very specific, and if it does not mention a panic test, then there is no panic test. In this case any hits/wounds are in complete isolation and we just move on.
    2. An effect/tactic card/etc, which cause d3 hits/wounds etc, 'short-cuts' the attack action process. So it simply starts the attack process at the point indicated on the card. So we play out the hits/defense saves/wounds/panic test (as applicable).
    Thoughts or clarifications on this?
    Thanks
    GR
    Thanks for the response. That's what we thought we be the case.
    Is there any I can refer to when calling it that way?
    Quote Originally Posted by GuessRange View Post
    Because the rules specifically tell you when to do things.
    They do not tell you to take a Panic Test any time other than resolving an Attack or when something tells you to, so you do not.
    Designer and Senior Developer
    A Song of Ice and Fire, Dark Age, Rum & Bones, World of SMOG: Rise of Moloch, Wrath of Kings, Xenoshyft
    So when a unit receives wounds from the Veterans of the Watch "Order: Counterattack", that unit doesn´t have to take a panic test?
    Correct. Order: Counterattack is NOT an attack action, nor does it instruct to take a panic test. Therefore, no panic.
    Perfect, thanks for the quick reply, I understand that the key word here is that it has to be an Attack "ACTION", understood.
