Problem with tc-20 Airbrush compressor
Results 1 to 3 of 3
Thread: Problem with tc-20 Airbrush compressor
    Default Problem with tc-20 Airbrush compressor
    When I turn it on it runs for about 2 seconds then shuts off . If i release the hose it will come on for about 2 more seconds . It Only Stays On if i dont have a hose connected. How can i fix it?
    Apr 2002
    Posts
    17,279
    38
    Quote Originally Posted by SheedaR View Post
    Someone else had this problem.
    http://www.coolminiornot.com/forums/...read.php?48436
    , and proud of it.
    I think it's the same person DR
    1. I'd ask the seller / company who makes the compressors, more likely to get a good answer from those who make it
    2. my first compressor had a similar problem. I cut out shortly after starting it. In my case the problem was the sensor used to measure how much the air is compressed (if too high, shuts the motor down) or the temperature of the motor and was busted, and had to be replaced. Whether you have the same or something else is beyond my knowledge.
    edit:
    found a tc-20 manual on the net, but it's not really informative. All it says that may be related: "It will turn off automatically when the power over heated." --> would suggest the heat-sensor problem
    also quite funny in the manual: "Do not use the compressor continuously for longer than 10 minutes" (altough not quite continuous, but I'm sure an AB session is longer for everyone (I usually AB for 1-3 hours before turnning my AB setup off) --> this could lead to broken sensors/other mech problems.
    Forgot, that it works again.
Tags for this Thread
