Charging if there is no place to fit
Results 1 to 3 of 3
Thread: Charging if there is no place to fit
    Default Charging if there is no place to fit
    In this situation, blue unit charges yellow. The red units belong to opponent. Is yellow unit a valid charge target?
    No, Yellow is not valid Charge target, as there is no space to fit the Tray-side the Charge would be on.
    Rule book (v1.4), page 18, on Charge:
    The LoS Arc of the target unit must have space for the attacker’s tray to fit
    While "corner" touches are possible after Charge when multiple (more than two) Units are involved, the Charger and Target must be able to align even a bit. In your image, they simply cannot align.
    Quote Originally Posted by Fronx View Post
    Ruling you quote is a part of a bigger paragraph. Whole paragraph is saing that only one tray can be aligned center to center or 2 trays at maximum. More to say align itself should be compleated after charge is declared sucsessful (attacker made a touch with target) Being able to fit can also mean that tray could finish charge movement without overlaping impassable terrain and other trays but in engage with target. And 1% cornering touch could be interpreted as the closest to 50% as possible
