Baratheon Warhammer Clarification
Results 1 to 5 of 5
Thread: Baratheon Warhammer Clarification
    Default Baratheon Warhammer Clarification
    Quick question, just to make sure.
    If baratheon warden attacks and generates weakened with warhammer, can it be expended immediately as vulnerable with target opening?
    If so, and the defender rolls a 1 again, can it generate weakened again?, but cant reroll because dices cant be reroll more than once per player.
    No. By the time you are generating results from Defense Saves you are past the point of being able to re-roll any of those dice- you've already generated results from the roll- and if you're still re-rolling dice, then you haven't generated any results, e.g. no "1" result has been rolled yet.
    You can't "claim" some of your results, lock them in, then try to modify others, which is what you'd be attempting here- dice are rolled all at once, then re-rolled, then results generated.
    Okay, but then is possible to make the enemy unit reroll with an already existing weakened token to make them reroll as vulnerable, then if the opponent rolls a 1, he will regain the weakened token right?
    Quote Originally Posted by Fullarchitect View Post
    Yes, once you "begin the cycle" of them having the token you could potentially and perpetually keep one in them, as long as they keep generating a "1" result.
    As answered above, by the time you'd place the Weakened token on the unit you've passed the chance to utilize said token, for the reasons listed above.
    Designer and Senior Developer
    A Song of Ice and Fire, Dark Age, Rum & Bones, World of SMOG: Rise of Moloch, Wrath of Kings, Xenoshyft
