Airbrush spraying water
Results 1 to 2 of 2
Thread: Airbrush spraying water
    Default Airbrush spraying water
    Hey so I just got an airbrush kit for the first time and as I was testing it without anything in it, after a while it started spraying water? Any tips on how to prevent that from happening? The pressure regulator or whatever it is also become a little cloudy?
    - does your system has a water trap? If not, get one as during the compression water condenses out of the air, which is sent to the AB
    - if you have a water trap, does it work or does it malfunction?
    while first two is the most likely, but have to ask if you dilute the paint too much? (if you get water spray even without using paint in the cup, then this 100% doesn't apply)
    Forgot, that it works again.
