Reply
Thread Tools Display Modes
Old 10-01-2008, 04:07 AM   #1
lahatiel's Avatar
lahatiel
Senior Member
Rep Power: 8 lahatiel is on a distinguished road
Default My wedding cake topper -- Reaper pirate and ninja (FINALLY DONE)
On October 11th, just ten days from now, I\'ll have the honor and privelege of marrying the love of my life. But like Romeo and Juliet, Tony and Maria, Buffy and Angel, she and I hail from opposing factions: in the great internet rivalry, Shelly is a pirate and I am a ninja.
Her own initial idea for a cake topper was to try and find some little plastic Japanese, tokidoki-style toys of a female pirate and male ninja. She wasn\'t having much luck finding what she wanted, though. Around the same time, she was also asking me to help out with more of the planning; among other things, then, I told her not to worry about the cake topper -- I\'d have that covered.
She tolerates my miniature-painting hobby with reactions ranging from bemusement at best to mild annoyance at worst (depending on how much time I\'m giving it versus her). She\'s joked several times since my pronouncement: \"No miniatures!\" However, she\'s really only used to seeing things like my Blood Bowl, fantasy-football-style figures, as well as things like Space Marines. So I took the chance that I could come up with something that, when done, would make her forget her \"no miniatures\" edict. She won\'t see this until it\'s done, but I got the approval at this stage of her best friend/maid of honor, so I feel safe about my decision.
Thus it came to pass, the union of Reaper Miniatures\' \"Sela Windsprite, Elf Pirate\" and \"Edo, Male Ninja\":
I looked across a wide array of ranges and various pirate/ninja figures, but these two were far and away the best for my purposes. Having them both be in fairly neutral poses, and lacking a lot of extraneous detail, was important. Our wedding will be weapon-free, but these poses made the weapon snips a relatively simple matter. Sela\'s pet monkey is actually a nice touch, because we both love monkeys and, in fact, one of my first presents to her was the Build-A-Bear pirate monkey stuffed animal she\'d wanted.
I was going to want to turn Edo\'s head; that way the figures could stand facing forward, while still holding hands and looking at one another, for which Sela\'s pose was already well-suited. And since Edo would be losing his head anyway, I decided to replace it with a bald one, giving him the personal touch mimicking my own shaved head. Luckily, I just happened to have a GW plastic bald head in my bits box. Detail-wise, that just left skulls on Edo\'s outfit... especially the large one on his back:
Those were all a bit much. And since I was already getting rid of those, I figured the pouches on his belt could go, too. So I started with a clip of all the weapons, as well as taking a chunk off the back of the ninja\'s new head. The head was shaped for a much more heavyset figure, and I was going to be adding a mask around the lower half anyway, to maintain his ninja mystique:
While Sela\'s left arm and Edo\'s right were in fairly good positions for the hand-holding, it turned out they were a bit too far off to simply be bent. Therefore, I chopped them off so they could be pinned back at better angles. I\'d also started taking off Edo\'s skulls and pouches, cleaning up the weaponless hands, and adding a bit of plasticard to Edo\'s feet -- the removal of his integrated base had left them a bit uneven, so I added two different thicknesses of card to rebalance them:
I reattached the arms, added the pins to the feet, and attached Edo\'s new head. You\'ll also notice I took some chunks off of Edo\'s new cheeks, too. Again, the face was too heaveyset and was going to be puttied over anyway; the bald head was all that was really important. Edo\'s hand was cleaning up fairly nicely, but Sela\'s were proving to be problematic; I cut them off after figuring it would probably be easier to sculpt new ones myself at that point:
I lined them up in a test post after beginning the putty work. I\'d started Edo\'s new mask and cleaned up his shirt where a skull had been removed. I\'d also started rebuiling his forearm where the sword hilt had been, and rebuilt the built where the pouch came off. Sela only needed some work on her shoulders where I connected the arms to by body and, obviously, I\'d added some wire work to the wrists to support the new sculpting. However, with time being a factor, two more Reaper Miniatures, \"Tristan Loremistress\" and \"Merith of the Flame,\" offered to lend a hand -- one hand each:
I went through other miniatures I had laying around and found that Tristan had a perfectly usable open right hand that could easily be swapped in. I hadn\'t thought that Sela\'s left hand would be much of a problem since it would wrap up with Edo\'s hand, hiding the inside where the weapon had been removed. However, the basic shape of the hand made that a more difficult proposition than first believed, as it was too closed; I needed a more open hand to fit into Edo\'s. Merith\'s left hand turned out to be perfect as, once the flame was removed (and again, the inside from where it would be cut would be hidden in the end, anyway), the hand itself was nice and flat as is seen better from the back:
With Sela\'s new hands added, I finished the putty work and the general mini prep. With them finally ready for painting, I took one last shot before spraying the primer:
I\'ve also made the boxes on which each figure will stand. They were made from 3mm Taskboard and are shown here stuck via bluetack onto popsicle sticks and sprayed with white primer. The tops on the right will be set into the boxes on the left and each figure mounted to one -- the boxes are actually sized so they\'re slightly wider than the spread of Edo\'s feet:
The texture of the Taskboard is a nice substitute for the wood surface of the real boxes they\'re designed to represent: the two boxes that are in the corners of the dance floor at Malediction Society, the Hollywood goth/industrial club where Shelly and I met. The real boxes are about 3 ft. high and 4 ft. and are there for people to climb up and dance on top; some do it to show off but for either Shelly or I, we would do so just dance with some space and air, away from the rest of the crowd. The mini boxes will be much smaller, relatively speaking, compared to the figures on top, but I obviously didn\'t want the boxes to distract focus away from the figures. The boxes will be a deep purple color with a golden fleur de lis design, as seen in the crappy cell phone pic I snapped one night before the club opened, so that I\'d have the design for reference:
While it helps that I work nights and Shelly works days, the toughest part by far has been trying to do all this without her knowing I\'m working on anything miniature-related. That\'s why I have the figures primered now, but didn\'t have time for that picture before she got home. I\'ll get a couple hours to paint on Wednesday afternoon before we have an evening appointment at the wedding venue, and then I\'ll have all day Thursday and Friday, with both those nights off, in which I hope to get the bulk of the work done. I\'ll try and get some updated shots posted in the interim, but that will depend on how my schedule (and hers) goes -- getting the painting done in time will be much more important than getting pictures taken right now! ;)
(edited for a couple of misspellings)
lahatiel is offline   Reply With Quote
Old 10-01-2008, 06:43 AM   #2
PegaZus's Avatar
PegaZus
Stealth Freak
Award-Showcase
Rep Power: 5 PegaZus is on a distinguished road
Good luck, and hope you finish in time! My own attempt at a cake topper turned out well, but it was simply repainting a couple of bears into pandas.
Items User owns 1x Cornish Rex User owns 1x Martini User owns 1x Black Tabby User owns 1x Beer
PegaZus is online now   Reply With Quote
Old 10-01-2008, 06:58 AM   #3
lahatiel's Avatar
lahatiel
Senior Member
Thanks, actual wedding date is a week from Saturday, the 11th, so I\'ll have time. I\'d just prefer to get as much done before this weekend as possible.
Old 10-01-2008, 07:28 AM   #4
supervike's Avatar
supervike
Superfreak!!!
Award-Showcase
Rep Power: 22 supervike will become famous soon enoughsupervike will become famous soon enough
I\'d have my reservations marrying a pirate.
Sure, they are sexy, intriguing and downright cool.
But, come on! Ninjas are on such a different level.
However, the topper does look pretty fantastic! You should try to get it all done soon though, as you\'ll have plenty to worry about the days before the wedding, and painting miniatures will only add to the stress level!
Best of luck to both of you. Marriage is not always easy, but it is worth it.
We want pictures along the way!!
Items User owns 1x Beer User owns 1x Black Tabby User owns 1x Martini
supervike is offline   Reply With Quote
Old 10-01-2008, 08:37 AM   #5
Monkeysplitters's Avatar
Monkeysplitters
Senior Member
Rep Power: 3 Monkeysplitters is infamous around these parts
am I the only one whose been to this site:
real ultimate power
according to this site ninjas and pirates are mortal enemies.
Monkeysplitters is offline   Reply With Quote
Old 10-01-2008, 09:06 AM   #6
DaN's Avatar
DaN
Freak!
Rep Power: 8 DaN is infamous around these parts
They say opposites attract :)
DaN is offline   Reply With Quote
Old 10-01-2008, 02:30 PM   #7
QuietiManes
Brushlicker
Rep Power: 7 QuietiManes is infamous around these parts
Pirates have guns...and rats...I\'d be very afraid if I was a Ninja. lollollol
Very cool idea, can\'t wait to see the end result.
Oh and congrats!
QuietiManes is offline   Reply With Quote
Old 10-01-2008, 02:36 PM   #8
airhead's Avatar
Rep Power: 14 airhead will become famous soon enough
Send a message via MSN to airhead
very sweet. I was privliged to paint the cake topper for my daughter\'s wedding.
It was much more traditional than yours, but they could not find one with the correct hair/flesh colors.
This also kept me out of the way of the girl\'s wedding preparations.
airhead is offline   Reply With Quote
Old 10-01-2008, 04:33 PM   #9
Kinslayer's Avatar
Kinslayer
Rep Power: 0 Kinslayer is infamous around these parts
If I get married, I sure as hell hope it\'s to a woman who even know\'s what the whole pirate/ninja thing is about!
Some women are just so shallow ><
but love the idea, all the best :beer:
Kinslayer is offline   Reply With Quote
Old 10-03-2008, 03:21 PM   #10
lahatiel's Avatar
lahatiel
Senior Member
Thank you very much everyone, for the encouragement and the kind wishes. It was time to take a quick break from painting, so I thought I\'d update with a couple new pics.
First, the shot I\'d taken after primering the figures, that I didn\'t have time to post before:
After primering them, though, I noticed a mold line across the top of the monkey\'s head. I hadn\'t noticed it on the bare metal because it was kind of hidden in the texture of his fur, but I realized it would\'ve been hard to remove for that same reason. Therefore, I sculpted a pirate hat over it instead, just like the one worn by the stuffed animal he represents (had I thought about this from the start, and had more time, I would\'ve converted him into the entire outfit worn by the stuffed animal; oh well):
Next, we have the figures with most of the basecoating done; if it\'s not obvious, the colors of our wedding are black with burgundy:
Plus one of the dance boxes the figures will stand on, with the fleur de lis painted on over Parafilm masking film:
And once the figures are mounted on their boxes, the boxes will go on this -- the lid to a peanut butter jar, of all things, spray-painted white:
Again, I\'m not sure if time will allow for more WIP pics before I actually finish, but I\'ll try if another break allows.
Oh, and @Monkeysplitters: Yes, I remember laughing my ass off when I first saw the Real Ultimate Power site, years ago. But of course ninjas and pirates are natural enemies... that\'s why I opened with the Romeo & Juliet / Buffy & Angel references. ;)
Old 10-04-2008, 02:09 AM   #11
EldredJonas's Avatar
EldredJonas
Newbie, please be gentle
Rep Power: 0 EldredJonas is infamous around these parts
Wow a pirate and ninja wedding ! :o
Mine was a drunk slob and a jane austen wedding ???
Loving this WIP, good luck with this and the wedding!
Jonas
EldredJonas is offline   Reply With Quote
Old 10-04-2008, 10:07 AM   #12
daddyo's Avatar
daddyo
Location: deeeeep in woods in gulf coastal mississippi usa
Rep Power: 2 daddyo is infamous around these parts
Cake topper. Cool. What a great piece!
And the hat on the monkey is perfect. No need to know there\'s a mold line under there.
We weren\'t drunk, but the minister that performed our ceremony seemed a bit more in his cups than just a nip or two of the sacramental wine... ???
(he dropped his bible and mumbled a bit)
Good luck in your marriage. :beer:
work hard, it\'s worth it. most of the time.
sometimes its more like :cussing:, but still worth it.
daddyo is offline   Reply With Quote
Old 10-09-2008, 07:59 AM   #13
lahatiel's Avatar
lahatiel
Senior Member
Circumstances did force me to show my fiancee the unfinished figures a few days ago. I caught her coming home from a bad day at work, so her initial reaction was poor when she saw that her \"no miniatures\" request had been ignored. However, once she settled in and relaxed a bit and I was able to really show her the figures, point out the details, etc., she really warmed up to the idea -- personally I think she just couldn\'t resist a teeny-tiny monkey wearing a pirate hat!
I\'m coming into the home stretch now, as I\'ll be finishing up between today and tomorrow for the wedding on Saturday.
First up is a pic I took the other day but didn\'t have time to post, after I\'d started to add some details and do some shading:
I also drybrushed the boxes a bit to bring out the texture slightly. Apart from being happy with how the fleur de lis came out, I\'m not all too concerned with them. You can also see the cork I added inside, which will hold the figures\' pins as well as provided extra glueing/pinning surfaces for putting the boxtops on, and attaching the boxes to the base:
Speaking of the base, here it is with the boxes undre the figures, to give a sense of scale:
And finally, the most recent picture of the figures as they currently stand. They\'re almost done, with the current to-do list reading: monkey, the pirate hair highlighting, another level of skin highlights, and a few other minor touch-ups (sich as the pirate upper lip) here and there:
I will throw up the standard defense of it being a poor picture, as it\'s under glaring direct light without my photo booth, which is both washing out some things while also creating some strange shadows. I also didn\'t really do anything to the photo other than cropping it so the colors are slightly off, etc. Right now, I\'m going for speed in the photos, not quality. However, we\'re obviously still not talking about Golden Demon quality here, or anything even close.
However, if you look at my CMoN gallery, I think it\'s safe to say that these represent my best work to date -- I\'ve really tried to push myself with these, and I must say that I\'m quite happy with the results. I continue to paint and practice so I know that I\'ll be a better painter in the future, and will paint better looking figures one day. But I honestly feel that there represent the best of my current abilities -- abilities that have grown during this very painting process, so that\'s all I could have asked for with the current results.
Old 10-29-2008, 11:40 AM   #14
lahatiel's Avatar
lahatiel
Senior Member
I finished the cake topper on time, barely -- glued the boxes onto the white base early Saturday morning, the day of the evening wedding! As such, though, I never had time to photograph it before the wedding itself, nor before leaving for the honeymoon two days later. But now that I\'m back, I finally got its submission posted; in the interest of keeping threads in their proper place, I started a new thread in Discuss Submissions:
http://www.coolminiornot.com/forums/viewthread.php?tid=29660
But I wanted to update this, just in case anyone who looked at this earlier would be following new posts on this thread.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©2009 CoolMiniOrNot Inc.
