hey guys,
i am new to posting on these forums, but i think that i have a few things to add here.
first, all of the things mentioned are good. i think that the best place to start is with conversions. i probably do conversion/sculpting work to 80% or more of my figs. you can look through my pics and see some examples.
eventually you might find that you don\'t like using armatures at all. if you worked in house as a sculptor, you would likely have your own armature cast as it would have your own feel to it. most of us don\'t have that luxury. whatever base you use is going to influence you work.
the wire that i use is from wal-mart of all places. i get it in the craft/floral area. it has 25 pieces, 18 guage, 18 inch, silver/grey finish, all for about $1. it is flexible enough to bend with your fingers and still holds its shape well. www.fibrecraft.com.
i then buy drill bits that match the size so that i can pin parts together. but i also use it as a frame for sculpted work as well.
one thing that i don\'t use is petro jelly. i can\'t stand the stuff. but there are two other options, and they are both free. the oil on your forehead and nose is the best at keeping the gs from sticking to your hands while mixing/rolling it out. just wipe your hand across you forehead and your finger tips across your nose before and during handling of the gs. i know it sounds weird. try it and then tell me you don\'t like how it works. the next thing is saliva. i lick my sculpting tools and blades constantly while working with the gs. be careful with them though. might poke your tongue or worse, cut it, ha ha.lol.
i am serious about this though. ask the guys that scuplt for a living.
the last bit and i will leave it alone for now. HEAT. it is your friend. on these hot summer days, 85+, i can sculpt something, sit it in the sun for less that 2 hours, and be able to work on it again. it has already set. some people build a heat can with an old coffee can and a lightbulb inside to make it warm to set their gs faster. i have not done this so far as all of my coffee comes in plastic bags. but it works.
and COLD. if you mix some gs and don\'t have time to finish using it all, drop it in the freezer. it will stay usable for a few days. it will set in there, but much slower. so that works great if you have to drop off the kids at the pool or grab a bite to eat.
hope that this helps your efforts some.
the last thing to keep in mind, don\'t be scared to experiment, it is only epoxy putty, and there is more where that came from.
j
