Thanks for the input Prophet.
Agree about AS or MS, so much easier to quickly press the shape in (with less sticking to tools too). And being able to easily carve and sand can be really handy of course.
Originally posted by Prophet
I do remember yellow heavy mixes seeming to stay soft forever though.
Aye, did a bit more yesterday: still soft enough to mark with a fingernail seven hours later when I was hitting the sack
Originally posted by Baz
Does anyone have any exact weight or proportional ratios for mixing? Or does anyone know the minimum amount of hardener that can be used?
This is something you can experiment with yourself quite easily - do some comparisons, see how it works out for you. It\'s not just about the working time though, the texture/feel of the putty can be quite different, enough that it is better or worse to use depending on your taste.
Anyway, many two-part putties (not all) are pretty forgiving in this area but you can\'t go too far as then you won\'t get a proper cure (so the finished piece is softer and less robust). With GS I\'ve used 4:1 yellow to blue and it\'ll still set, eventually; it\'s very weak. I\'ve tried about the same with MagicSculp but the hardened putty is too crumbly for my taste* and unheated I\'ve seen it take 48 hours or longer to get past the \'leather hard\' stage!
Two things I would advise if you\'re using low proportions of hardener:
mix
very thoroughly;
use heat for curing.
*To get the kind of looong working time that this was intended for I would instead recommend that you blend a 1:1 mix of MS with SuperSculpey or similar. You can get two or three times the length of sculpting time no problem, then set in boiling water or a low oven.
