Originally posted by QuietiManes
Well yeah, but you know you can mix both putties together at the same time right? Just stack all four parts up and go to town. Doesn\'t take me much longer than mixing just the 2 parts of one putty.
It\'s a better idea to mix them separately, then blend the two, just to be on the safe side.
My main reservation about this is that Milliput can often be a right whore to mix, irrespective of anything else. From what I\'ve tried it\'s the worst for major finger stickage (compared to MS for example, where usually there\'s
none) and on top of that when old, or any time the temperature is low, it can be so stiff it\'s actually painful to work with.
These are the main reasons I first looked for an alternative, but Milliput is also well known for having a limited shelf life - one or both rolls forming a leprous skin - while with MagicSculp (and I think Apoxie Sculpt too) they seem to last indefinitely.
By the way, forgot to mention a good tip - the best way of doing blends IME is mix both putties, then flatten the GS and wrap it around the ball of Milliput like a blanket. Squish it, fold it, squish it again, fold it, then start rolling between the hands. Roll and fold, roll and fold, and before you know it you\'ve got a homogenous blend, without much putty sticking to your fingerprints.
The roll-and-fold method is the best way of mixing all epoxy putties if you haven\'t tried it.
P.S. Always wash hands after mixing putty if you don\'t wear gloves.
