El Matador
Hello friends,
i am new to both the hobby and the forum and i have some questions that i think are important...
First of all i was really inspired by most of the work here at CMON especially by Vincent Huden and Sebastian Archer and decided to start painting. I started out by reading some of the articles and realy thought i was all set to start painting and immediatly incountered my first problem embaressingly :redface:. I found that there are numerous articles excellantly wrote about glazing, feathering, blending, model prep and juicing ect however my problem was actually basecoating :redface: i have two different primers (citadel skull white and chaos black) however almost instantly after that i realised theres a \"gap\" for basecoating articles. Normally i would just put a median colour and then do a simple highlight and shade (i play the game quite alot and am used to painting armies
) however after reading a few articles im fairly certain this is what i should do only i should use a colour much closer to my highlighting colour?
I also tried out the juicing techneque that Sebastian Archer explained in an article and the difference was quite signifigant however somtimes it appeared almost dusty. It appeared to happen only with certain colours mostly blood red and white. Is this because of the paints or the way i am applying them?
Finaly on one of the three practises i started with a chaos black under coat and attemped to slightly tint the surface however 150 coats of scab read later i was left with an uneven coat. I had followed some of the tutorials and my paint was super dialuted ( around 30/1 water to paint) and ever time i put my brush in the water i wiped it off similar to dry brushing. Do you think this could be because of the brush i am using? At the moment it would be hard to distinguish it from a yard brush
For those who have made it to the bottom, thank you for reading any advice you give is appreciated, Thanks and Hello
