tootskater
So I was goin thru some tips over the web and they said somthing about Highlighting And I was wondering if Highlighting was the same as drybrushing just more cotrolled?
Originally posted by supervike
When I first discovered drybrushing, I had thought I found the key to mini painting. I used it to highlight EVERYTHING...Much later I realized the problem is, it tends to look chalky, rough, uneven.
As I start to learn more of the layering process, I too find myself drybrushing less and less. I still don\'t understand how you can layer fur without drybrushing, but I know that to achieve smooth even results, I am going to have to find out.
Originally posted by Klute
My method for fur and hair is sort of a mix of dry brush and layer.Paint not too thin but plenty on the brush,now run the side of the brush over the area very controlled.
Now when you do your painting demos you can tickle everybody with your \'feather technique\'lollolOriginally posted by Cerridwyn1st
Geeze, I\'m a featherer and I didn\'t even know it! Thanks for explaining it, Tammy. I\'m also a fan of \"tweening\", but I find that to get the transitions smooth on the final blend, that I\'ll lay color and then spread it out with a damp brush while it\'s still wet. Just like the feathering Tammy discribes.
Originally posted by t_haye2
euwh.......i\'m weird, but not that weird...
Hey, check it out, my 500th post! I got me another star!!!
Well it seems I have my uses after all........lol :flip:Originally posted by dauber22
HOooHa! COngradulations, Tammy! See! Argueing with DragonsReach has it\'s pluses![]()
