Having to add more limbs to the willow tree, as the fronds/foliage isn\'t hanging right at the moment - although it does look ok.
I\'ll get some more photos up soon.
For the meantime I also came up with something else... Usually, when we strip the insulating plastic of a wire we throw it away... But then I wondered if it could be recycled...
Here\'s the empty, hollow plastic tube which insulated the wire (Which is now being used in the willow tree)...
I cut it in half, and was pleased to see that it held it\'s curved shape, so I then used a pair of sharp scissors to shape the end into a long point.
I then wrapped the plastic around (Bending it back on the outer edge of it\'s curve) and started to superglue a few of them together, with the pointed ends splaying out.
I think you can see where I\'m going with this now
I continued until I had a good few long lengths in the centre, and then made a few shorter \"leaves\" to glue around the outside at the base.
And the end result is quite good IMO - in this case due to using green plastic it hardly even requires painting... And, if done slightly differently, could also be used to represent tree fronds, like those on a palm tree or similar...
