VGC Heavy Grey - Highlight and Shade Colours?
Minigiant
I am looking for suggestions on shade and highlight colours for VGC Heavy Grey
I thought maybe Smokey Ink would be a good shade, and Plague Brown as a highlight
MAXXxxx
Simply black and white ? That grey looks pretty much like a neutral grey.
But if you want a more colorful shadow/highlights:
- Dark Blue Gray , Ghost Grey
- Mahagony , Ivory
- Dark Blue Gray, Ivory
MAXXxxx
my eye is getting worse and worse...
anyway if it's green, then:
- shading with a red/redbrown(VAC-HullRed/VAC-TankBrown for example, VGC-SepiaInk if you want to stay with VGC and inks) and highlighting with a yellow (Ivory again, vgc-off-white is similar if you want to stay with VGC, but the plague brown is a yellow shade too) would work.
This is basically the same what you thought about, but: Smokey Ink has a bit of a textrure, so instead I'd use sepia ink (similar shade, no texture), highlight(Ivory) is much lighter. The plague brown would only make the Grey it more yellow, but will not change the lightness enough imho.
- or if you want to go a colder: shade with blue (dark sea blue) and HL with yellow (ice Yellow (cold yellow, bit greenish hue))
