BlackTooth
Hello,
I\'ve tried my hand at this blending/feathering stuff and I\'m having mixed results. There seems to be some ambiguity over the net regarding what blending is, so I\'ll explain what I\'m doing. Hopefully I\'m usuing the right words to describe what I\'m doing.
Right-o. I\'m highlighting model by putting a layer of paint on top, cleaning my brush, and then smudging the edges so it makes gradual layers of highlights.
As said above, I\'m having mixed results. Some parts look really good, but others look patchy or grainy. I\'ve been using Scorched Brown as a base, and applying Bestiel Brown over the top. Am I supposed to mix the colours for layers in between? I was told not to, as by gently easing out the highlight colour it should give gradual highlights but mine looks a lot brighter than I expected.
Also, I was informed that in order to get this technique to look really good you need to do a lot of layers, yet I only do about 4 and the paint becomes as bright as it can. I\'ve tried watering my paint down to different levels. Sometimes it\'s too watery and doesn\'t stick the the model and pools in odd areas, so I water it down a little less and get only 4 to 8 layers out of it. Should I be adding some kind of glaze medium to help it or something?
Also, should I be starting with the darkest colour and working up? Or painting on a base and then putting in the shading and highlights?
Thanks for the help! :drunk:
