enion dont get your knickers in a twist it s just a debate not personnal...
Don't be obtuse, you're the one who took it to a personal level by implying someone was talking out of their ass.
dannyboy2k im not suggesting that at at all im simply trying to make the point that a larger mass travelling at high speed conveys more kinetic energy to the target than a smaller one.
And this is for practical purposes irrelevant:
"Kinetic energy does not wound."
For everyone else: the energy of the bullet is of course a factor, because together with projective shape and material composition it directly affects penetration. But the amount of kinetic energy transmitted to the target is
irrelevant - for those unaware of the numbers, it's often a surprise how very small it is:
"Goddard amply proves the fallacy of 'knock-down power' by calculating the heights (and resultant velocities) from which a one pound weight and a ten pound weight must be dropped to equal the momentum of 9mm and .45ACP projectiles at muzzle velocities, respectively. The results are revealing. In order to equal the impact of a 9mm bullet at its muzzle velocity, a one pound weight must be dropped from a height of 5.96 feet, achieving a velocity of 19.6 fps. To equal the impact of a .45ACP bullet, the one pound weight needs a velocity of 27.1 fps and must be dropped from a height of 11.4 feet. A ten pound weight equals the impact of a 9mm bullet when dropped from a height of 0.72 inches (velocity attained is 1.96 fps), and equals the impact of a .45 when dropped from 1.37 inches (achieving a velocity of 2.71 fps).
A bullet simply cannot knock a man down. If it had the energy to do so, then equal energy would be applied against the shooter and he too would be knocked down. This is simple physics, and has been known for hundreds of years. The amount of energy deposited in the body by a bullet is approximately equivalent to being hit with a baseball."
as for the nervous shock issue if you are struck hard say by a night stick on the upper thigh in the area you would normally punch someone for the dead leg effect...
Let's look back at the original mention and not this irrelevant sideline:
the larger the round the more energy transfered to the target more trauma is caused the greater the effect on the nervous system hence more stopping power, simple ballistics really.
The quotes I provided are evidence that energy transfer is
not a cause of trauma (there is an abundance of further proof of this for anyone who cares to look it up) and such trauma is
not a source of effects on the nervous system - to be clear here, this was taken to be a CNS reference, not direct effect upon a nerve.
the nervous shock effect is one of the reasons your tought to aim for central body mass as even if you dont hit anything important the resultant shock cause's the body's nervouse system to shut down and once again you fall down in a big twitching heap.
Cough:
"The much discussed "shock" of bullet impact is a fable..."
The reason that shooters are taught, or at least should be, to shoot for the centre of the chest is
because that's where the heart and upper spine are - direct damage to either is the goal, "because of the impracticality of training for head shots".
"The only method of reliably stopping a human with a handgun is to decrease the functioning capability of the central nervous system (CNS) and specifically, the brain and cervical spinal cord. There are two ways to accomplish this goal: 1) direct trauma to the CNS tissue resulting in tissue destruction and 2) lack of oxygen to the brain caused by bleeding and loss of blood pressure."
the crush effect and cavitation you mentioned as nonsense hmmm whats that caused by oh yes the shock wave travelling in front of the or behind the round...
I didn't say they were nonsense, read what I posted. And more importantly, read the quote, which is very specifically on-topic.
"Temporary cavity does not wound."
More on this (warning for anyone a bit squeamish):
"Probably the most exaggerated account of temporary cavity effect in the literature appears in High Velocity Missile Wounds by Owen-Smith. His Fig 2.20 on page 35 shows a lesion in a pig's colon caused by a "standard bullet fired at 770 m/s (2500 ft/s)." Concerning this wound, he states "there are microscopic changes of cell death extending 20 cm from the edge of the hole in the colon; this is why such an area must be resected if it has been damaged by a rifle bullet." Perusal of the source document of this picture, however, reveals that a deforming soft-point hunting bullet was used for this shot. In describing the effect of this shot, the source document states, "...haemorrhage extended macroscopically to a diameter (my emphasis) of 20 cm." When the 8-cm hole diameter is subtracted, a 6-cm distance (rather than the 20 cm reported by Owen-Smith) from the edge of the hole on each side adds up to the "diameter of 20 cm" reported by Scott in the source document. Furthermore, photographs of bowel defects caused by bullets must be viewed with caution. Folding back the bowel wall around the edges of the hole can make tissue defects appear larger. If colon tissue at a distance of 20 cm from the bullet hole is killed, as asserted by Owen-Smith, what happens to the loops of small bowel and other organs that are within 20 cm of the bullet hole? Are they killed too? If so, this would equate to destruction of most of the abdominal contents by every penetrating "high-velocity" bullet. Clearly, this conclusion is inconsistent with well established available facts. A study done in our laboratory, for example, showed damage to a pig colon caused by a nondeforming military bullet traveling at 911 m/s (2989 ft/s) that was only slightly larger than the dimensions of the bullet that had caused it.
It should be noted, however, that stretch from temporary cavity tissue displacement can disrupt blood vessels or break bones at some distance from the projectile path, just as they can be disrupted by blunt trauma. We can produce this in the laboratory by careful choice of projectile and projectile trajectory in tissue, but in practice this happens only very rarely. Data from the Vietnam conflict show that the great majority of torso and extremity wounds were attributable to the damage due to the permanent cavity alone."
look up blast trauma in your big book of facts. nothing but the blast wave hits you, no shrapnel (the same as the shock wave you get from a bullit)
Oh I'm so glad you said that too:
"The sonic boom experienced after passage of a supersonic airplane is an example of a sonic pressure wave. This pressure wave travels at the speed of sound in the medium through which it passes, and sound travels four times as fast through tissue as it does through air. Thus the sonic wave precedes the projectile in tissue. Contrary to popular opinion, this wave does not move or injure tissue. Harvey's exhaustive experiments during WW II showed clearly the benignity of the sonic pressure wave. The lithotripter, a recent invention that uses this sonic pressure wave to break up kidney stones, generates a wave five times the amplitude of the one from a penetrating small arms projectile. Up to 2,000 of these waves are used in a single treatment session, with no damage to soft tissue surrounding the stone. It would be difficult to imagine more convincing confirmation of Harvey's conclusions."
For those interested in doing further reading, the quotes above in blue are from
What's Wrong With The Wound Ballistics Literature, And Why by Martin L. Fackler, MD. That'll give you a good start if you want to know more - Fackler is America's foremost expert on wound ballistics. The quotes in purple are from
Handgun Wounding Factors And Effectiveness, written for the FBI Academy Firearms Training Unit.
here endeth the lesson for today
:foot-in-mouth:
