Originally posted by djinn24
I was asking for a supplier and thank yout for the different selection posted as well.
Welcome.
From what i understand and have read in this post they are somewhat like the other pains but are think and need to be thinned and tend to dry semi transparent?
Thick, yes; semitransparent, not always. As I mention in the thread linked to above, paints of this type will tend to exhibit the natural character of the pigment used (as opposed to hobby paints which are made to be fairly uniformly opaque, generally speaking).
Some artists\' acrylics are
very transparent because that\'s what the pigment is naturally like. A number are very opaque (like Titanium White, Mars Black, Yellow Oxide, Red Oxide to name a few). And others will fall in the middle zone somewhere - semitransparent to semiopaque.
With regard to the consistency, many of the tube acrylics aren\'t as thick as the \'heavy body\' designation might suggest (and they can vary from colour to colour because of poor QC!) but if you assume that they\'ll be roughly like toothpaste you\'ll have some idea of what to expect. I would suggest using a steel or plastic palette or painting knife to reduce their consistency, adding water by just dipping the blade into your mixing water and dripping into the pile of paint, mix up, gather into a neat pile and then add more water if necessary.
Windsor Newton has a line of paints called Winton that I would not recommend unless you want very transparent paints.................that can be a plus in some situations.
Galeria
Winton is the cheaper oil range.
