Addictive game!
Hinton
Originally posted by Aliengod3
Awash - http://FantasticContraption.com/?designId=1650653
My \"Awash\" is almost exactly like yours:
http://FantasticContraption.com/?designId=1652340
I didn\'t save too many of my designs, but here\'s the one is made for \"Four Balls\":
http://FantasticContraption.com/?designId=1644488
EArkham
Necromancer
I guess some of these require similar solutions after all. Mine for Awash was like the previous two, only I had a flail (I recreated it so I could save it):
http://FantasticContraption.com/?designId=1664599
And this was mine for Four Balls (again with the flails):
http://fantasticcontraption.com/?designId=1646779
Edit - And here\'s Back and Forth:
http://FantasticContraption.com/?designId=1665052
Edit Again - Here\'s my version of Tube. I wanted to see how simple I could make it while keeping it interesting:
http://FantasticContraption.com/?designId=1683088
Kep
Aliengod3
http://FantasticContraption.com/?designId=1679870
http://FantasticContraption.com/?designId=1678927
http://FantasticContraption.com/?designId=1689246
EArkham
Necromancer
Hee, believe me, it took a long time.
Finally got Unpossible, too, and this one took even longer:
http://FantasticContraption.com/?designId=1692085
Now I can go back and look at how everyone else did their Unpossibles, heh.
Edit - Ah hah, Aliengod tried the catapult method, too. My first plan was to make an unfolding ramp, but the ramp took up too much room in the starting area and I couldn\'t fit the towing vehicle.
Edit Two - U-Turn, by comparison was much easier. Between the time I posted and now, figured it out:
http://FantasticContraption.com/?designId=1693000
Kep
Aliengod3
Ya my Unpossible took a boat load of trial and error to get the right amount of wood wieght and water weight for the flail piece.
You catapult looks alot more sophisticated than mine. I guess I have an orky mind when it comes to mechanics.
EArkham
Necromancer
Yah, once you figure out catapults, it makes a lot of them easier:
http://FantasticContraption.com/?designId=1706306
Basic catapult (add more wheels for more power, just make sure the connections are symetrically linked):
http://FantasticContraption.com/?designId=1706375
Edit - And another quickie. I never get tired of throwing things around apparently!
http://FantasticContraption.com/?designId=1716425
Kep
Originally posted by Amazon warrior
I discovered this a couple of days ago. It\'sincredibly addictive, and I have finally caved in to its constant demands to be shared with you all!
Fantastic Contraption
Curse you *shakes fist* :D
I deliberately didn\'t look at anyone else\'s to try to be as original as possible, although some are so simple I think you\'re bound to do something very similar if you\'re going for the simplest solution.
On A Roll
http://FantasticContraption.com/?designId=1735330
Stairs
http://FantasticContraption.com/?designId=1730316
Big Ball
http://FantasticContraption.com/?designId=1730723
Four Balls
http://FantasticContraption.com/?designId=1731184
Down Under
Anyone else have a chain break?!
http://FantasticContraption.com/?designId=1731485
http://FantasticContraption.com/?designId=1731575
Awash
http://FantasticContraption.com/?designId=1731910
I thought I could make it simpler, didn\'t realise how much I could cut it back and still have it work and what\'s more it does it faster!
http://FantasticContraption.com/?designId=1731939
Handling
http://FantasticContraption.com/?designId=1732121 (so close!)
http://FantasticContraption.com/?designId=1732144
Tube
I think this is the simplest solution possible:
http://FantasticContraption.com/?designId=1767170
Unfortunately I never thought of a catapult myself and it seems it might be the only way to solve Unpossible.
Back And Forth (finally!)
http://FantasticContraption.com/?designId=1825717
U-Turn
I thought this was much easier than the preceding two.
http://FantasticContraption.com/?designId=1771822 (wheelbarrow)
4 Balls - http://FantasticContraption.com/?designId=1659995
This doesn\'t work when I play it - last ball doesn\'t make it and gets caught in a loop.
Big Ball - http://FantasticContraption.com/?designId=1663505
Very elegant solution.
Stairs - http://FantasticContraption.com/?designId=1670315
Very inventive! But it neeeearly gets there and gets stuck???
I think you get the prize for least number of elements for this one
Aliengod3
My contraptions are weird because they worked the first time but never worked afterwards. Does not make any sense to me either, haha.
These ones work AND are fun.
http://FantasticContraption.com/?designId=1698235
http://FantasticContraption.com/?designId=1671239
Roger Bunting
Here\'s mine for Unpossible.
http://FantasticContraption.com/?designid=1809277
EDIT: Hmm, it seems to link to the main page....grr.
Originally posted by Roger Bunting
I didn\'t use a catapult for unpossible.
I\'m still stumped! Probably a mental block at this stage... will have to come at it cold, see if something new pops into my head :drunk:
I was wondering if sometimes when these run there might be minute differences - I\'m sure I spotted slight changes in movement once or twice while doing test runs.
