Airbrush compressors.... what makes them good or bad?
Well compressed air is compressed air right? Not quite, with a good compressor intended for spray work you have a tank and an inline moisture trap, at least one of which is considered a must-have for airbrushing. I don't know what these small tyre compressors are like for build quality and motor run-time but they are obviously intended to be used to pump a few tyres then be turned off, which is quite different to what you might need when airbrushing.
PegaZus
Stealth Freak
Course, you could inflate an inner tube, then use that as the source. Old school and horrid control. For a few dollars more, you could get something more suited. Use a regular tanked tool compressor myself. Water/oil trap with extra long hose.
QuietiManes
Those tire pumps tend to overheat in a few minutes. Also, note, it is 100 PSI that it can inflate up to...not 100 PSI airflow that it can maintain...huge difference. The amount of air they move is usually very low as well, a fraction of the higher priced compressors.
You could use it to fill a canister as Peg suggests, probably with decent success and longevity, if it's a decent sized tank.
"Airbrush/hobby" compressors are over priced. "Garage/air tool" compressors are usually better options, you just have to make sure they have (or you add) pressure regulator/moisture trap/storage tank (ideally)/etc...and be aware of their noise level. Most airbrush compressors are very quiet, most garage compressors are quite loud, but there are quiet ones (more expensive but still far less than the airbrush equivalent).
Phoulmouth said:
http://www.amazon.com/Master-Airbru...354352182&sr=8-1&keywords=airbrush+compressor
There you go. 90 dollars american isn't bad. Plus it seems to come with everything you need. Cheers.
With this kind of unknown-brand compressor you just don't know what you're getting, hence there are frequent cautions given about buying one. Ditto, in spades, for the airbrush because of the unknown quantity it represents (particularly if there are no spare parts, which are not merely desirable for traditional-style metal ABs).
GraveRisen
Yeah I'd go with a mastercraft/some other garage compressor before a no-name hobby one, I'll just hit up rona/lowes/home depot and look for a small quiet tank compressor with a moisture trap
This ^
Good advice.
Add a regulator if it does not come with one.
Add a moisture trap.
Pickup some quick couplers and you're set.
denstore
I have tried most solutions for compressed air, and in the end I got a purpose built airbrush compressor, that I I've modified to fit my needs.
First, I borrowed a friends home built silent, refrigerator type compressor. It worked absolutely perfectly. If you are above average handy with tools, this is a very good way to go. Second hand refrigerator compressors are very cheap, and coupled with the parts from a garage type compressor, it is an easy and inexpensive way to get a silent setup.
Then I had a couple of years with a Testors airbrush compressor. It was probably the worst experience. Almost as loud as a garage compressor, no tank, no reliable regulator and not exactly cheap either.
After that, I went CO2-tank for about a decade. CO2 works perfect for airbrushing, and is the most silent alternative. But the drawback was that it tended to make me be conservative with the use. I always tried to find reasons not to use it, to save on the gas. In the end it made me not to evolve in my airbrushing. To be good at what you do, you need to experiment and practice. When you know that every time you open up that valve, it will cost you, you stop doing it. I'm thinking of getting a CO2 setup again, but mostly as a portable air source.
Then I had a couple of different piston type airbrush compressors, and a garage type compressor. But living in an apartment made the noice a reason for not firing up the compressor, and I was back at not getting the needed experience.
Now I have a Sil-Air silent compressor. I love it, and I think it was worth every cent. I have made some changes to fit my needs, but I could have lived with it as it came, if I wasn't especially picky about my stuff.
