StingrayP226
Ok just got an Airbrush (traded for it... only took a year to get the airbrush I traded for but that is another story) "from a friend" its a Snap On BF170A, which leads me to believe I not only waited too long but got ripped of as it was not worth what I traded for it (or was led to believe as I trusted the guy). Anyway. Issues aside I picked up a Badger AS180-12 Compressor (no tank) and got a regulator and Air filter from Lowes. Now I have NO idea the size needle I have on this thing (likely a 0.5) and it seems to work fine from a distance, but once I get up close I get that watery "splatter" (looks like a web or paint splatter). I read that could be a pressure issue so I lowered the Regulator to around 15PSI (or so it says), and keep having that issue. I put the pressure any lower and no air comes out (or so little its a joke).
Another strange thing that I noticed is when I press down on the trigger to get airflow I have to wait a second before the airflow actually gets up to full pressure. Is this normal or have I chosen a Compressor poorly (I thought I saved my receipt but looks like it might not have actually been saved... just my luck)?
Or is this all because I'm still a newbe with my airbrush and need more practice before I can get this darn set up to at least spray a good line when up close?
Also I use watered down (with windex) reaper paints.
