MPJ
OK, so I'm on a short break from minis since I've become inspired to assemble and paint a 1/570 scale model of the Titanic I've had sitting around since 1976. Normally when I airbrush a model I don't prime first and this has always worked just fine with the Tamiya acrylic paints I mostly use and also with various enamels. However I had an excess of Chaos Black GW paint and needed some black for the display stand so I loaded it up into my airbrush and started spraying but what a mess it made. It came out of the airbrush just fine but was pretty much repelled by the plastic. After washing off the GW I loaded up the last of my Tamiya black and as expected it worked just fine. After I tried some Reaper paints through the brush, again it flowed fine but didn't adhere to the plastic (though not as bad as the GW paints).
So I guess my question is... What is the difference between these paint types that makes it so the 'mini' paints don't airbrush directly onto the plastic? Will priming solve this problem? I have a Reaper color that would be perfect for the antifouling (below the waterline bit of the hull), I'm having a heck of a time finding the right color in another paint and I'm trying to be as accurate as possible with my colors.
Side note: For those interested in historical color matching type stuff I found this website http://titanic-model.com/paint/ where I'm getting my color references and Reaper Master Series color Rust Brown seems about perfect for the antifouling mentioned above.
