Any tips for using sculpy?
War Griffon
Thinking of using sculpy for the first time anyone got any tips?
Do you need to keep your tools wet as with green stuff?
Do plasic bases melt in the oven if put in with Sculpy?
Any help appreciated.
Many thanks
Martyn.
Strateegos
Sculpy is great for lots of stuff as long as you do not use it on your figs and then bake them (will definitely melt or disfigure your figs). Use it for terrain and scenic bases that type of thing.
A few working tips:
Knead it until it is in a \"workable\" state, that is, knead it into a ball, cut in half, put back together and then rub your finger along the seam and the seam should disappear, if it does not, knead some more.
Generally follow same tool techniques as with \"greenstuff\".
Most definitely us a GLASS plate to bake it with, anything else will burn unless the item is suspended in the oven.
Hope that helps
Steve:idea:
Medved
use small amounts! build it up in layers or keep the thing you are sculpting not too thick. otherwise it can take ages to bake.
wet your tools as said before but not too wet otherise the sculpey will not stick to anything.
oh and you can half-bake it so that the putty goes quite hard but you can still sculpt on the surface and then do a final bake later
what are you thinking of making martyn?
First, spell it with an e lol
Which version are you using Martyn, Sculpey, Super Sculpey (green and white box) or Sculpey III? Apparently there\'s quite a difference between them.
I have a guide on my Mac which I\'ll need to go check to remind myself of a few things but kneading\'s very important to get a good working consistency as mentioned.
If it\'s a bit soft when you\'ve roughed out your basic shapes (I find it very hard to use because it\'s so soft) you can pop it in the fridge to stiffen it up.
You can use Sculpey\'s diluent with a brush for final smoothing but I\'ve read that it\'s easy to overdo this and weaken the surface (it leaches out the binder). This can also be done with methylated spirit I think.
Thin sections and projecting areas can be protected from overheating by wrapping (gently obviously!) in aluminium foil.
Letting the piece cool in the oven after it\'s turned off is a tip I\'ve read many times, helps prevent cracks but if you\'re working very small you shouldn\'t have much trouble with this.
You probably won\'t have to use wet tools to prevent sticking, polymer clays don\'t have the same sort of surface that other types of sculpting compound do and when I\'ve played with it I didn\'t have any problems with my tools sticking.
Shouldn\'t, the temps should be quite low - you can set these sorts of putties in boiling water - but thin plastic will have a tendency to droop so watch out for plastic weapons or anything made from plastic card. Longer baking at lower temperatures can work as well as less time at a higher temperature but you\'ll want to read up on that for exact temps.
There\'s an absolute ton of info on polymer clays online if you search for it you\'ll find loads of help from doll makers and people who make beads, canes and other jewellery applications.
StarFyre
awesome tutorials
Here is a step by step of a professional (ie. hollywood film industry vet) making a model with super sculpey + sculpey III.
It\'s quite large..a foot or so long + , but awesome info.
http://www.conceptart.org/forums/showthread.php?t=18287
Sanjay
War Griffon
Many thanks Medved, Einon and Strateegos for your help.
I want to have a go at making some bases with a veiw to casting them in resin at a later stage Sculpey was a cheaper option to greenstuff for the main areas.
The Sculpey I have is the Sculpey III.
Is it best to use gloves to avoid finger marks as with green stuff or does it smooth out a lot better and therefore doesn\'t matter?
Martyn
(Being Welsh I have always struggled with English but then I can\'t speak Welsh either :D)
QuietiManes
Highly reccomend you invest in a pasta roller \")
I find the softness of Sculpey III a little too much. Much prefer Super Sculpey or Fimo. III is cheaper and easier to find though generally. You\'ll have a real problem NOT getting finger prints all over the III once it warms up after being worked a bit.
