Arcadia Quest Azure ability question.
foosninja
Azure's Arcadia Quest card reads "Rolls +1 defensive dice for each unspent movement point."
This seems semi-clear if it is used on Azure's activation. But does the power apply at all on opposing figure's activation?
AND - the unclear part - If Azure attempts to move....here lets use an example.
Azure is two squares from an opposing Monster. Azure moves once and is now close to the monster, and has used up 1 movement point. Now Azure attempts to move again triggering a guard reaction. Azure is attempting to move out of the "close Square, which triggered the guard reaction", and as such the combat is rolled before the move is made to the new square. (so if he died he would drop all carried exploration tokens in the close square.) So my guess is that even though Azure is attempting to use his second movement point, because the attack is made in the 1st square he moved into, he technically still has 2 movement points "unused" at the point the attack occurred. Is this a correct interpretation? Or would he only have 1 unused movement point because the attack occurred while attempting to use his second movement point?
And again my other question is: Does this power work at all during an opposing figure's Activation, and if so is it based on the opposing figure's remaining movement points?
foosninja
A representative from CMON just contacted me via e-mail and answered this question.
Azure's power only works while Azure is active. So it provides no benefit during other player's activations.
And in the example above, Azure was attacked while attempting to use his second movement point, so that means he has only 1 point of movement remaining at that point, and would receive +1 defensive dice bonus.
That was the "Official CMON ruling".
