kittykat23uk
Jenova,
Thanks for being so honest, I like your work a lot too, you do seem to have the upper hand when it comes to blending right now, although I think you could do with improving on those bases of yours (not too keen on those glossy purple ones in the CMON book!
). I have been trying to improve my blending over the past year and I do agree that I have a way to go before getting into the 9-10 range. Although I think perhaps people are becoming tougher with regards to giving out higher scores. IMHO super smooth blending should really only be a major factor in the 9 to 10 range. For the 7-8 range I would expect to concentrate on overall look of the mini, general basing, neatness and colour choice.
All I can say though is that part/ a lot of my problem is the camera. Taking the orc as an example, those little white dots that seem to be concentrated around the right arm and into the elbow do not appear to be there in real life. They are actually a result of enhancing the focus in XN View to create a sharper image.
Maybe you are right about the shading on the red, brown and green - it\'s there in real life but is lost in the picture. However, if I overcompensated for that in the painting, I think it would look worse in real life. The red is highlighted several times over, as is the green but again, looking more closely at the pic I see that the photo has oversaturated these areas and the shading and highlighting that I did has been somewhat lost. Also the crossbow and face of the orc are a bit out of focus which doesn\'t help. I agree that the orc itself is worthy of around a 7, which is supposedly equated to \"pretty good\". This was my first ever greenskin btw, so I\'m happy with that. I am more concerned really about the wolfen, which I think are better than the orc.
Regarding size of pictures, I can already see in this pic that the compression rate has created artifacts around the edges of the picture. The size of this one is about 80-90K. Any larger and I loose more clarity because of the 100K limit.
I also believe that recently a lot of stuff that I\'d consider an 8 or 9 has been marked lower- the recent UK Gamesday runners up and even some of the winners for example (a 10 is supposed to be golden demon quality, but even golden demon winners don\'t often get out of the 8 range and runners up are in the 7 to 8 range).
Having said all this, I do still believe that overall the diorama and the wolfen in particular deserve better than the scores they had received. This is a conclusion I have reached based on comparing these pictures both to earlier pics of my own and also looking at the CMON annual and othe people who paint wolfen on the site. I.e. I believe that Chern said all the pics that went into the book had scores of at least 8.2. I don\'t think that these pictures are really any worse than the ones that Vahilor or Lilli Troy have of their wolfen, in the book Lilli\'s Watcher in particular looks very rough in comparison to the pictures I\'ve posted.
So I\'m guessing that another issue is as Finn said that people are just getting harsher. I will continue to try and improve on the areas that I am weak in- blending being one, and also continue to try and get better pictures and composition with my camera. But it saddens me to think that at this rate I\'m not getting any closer to being in the next annual, which would be a major achievement and something that I\'m really trying to aim for.
Regards,
Kat
Regards,
Kat
