Article: Imperial Guard Building
A Luna
A Lunatic
..So is your comment Junior elf... Well explained to me, its not the end result that matters, its the article. For tabletop, this is ok to me.
Fade 13
This wouldnt be a tabletop centerpiece by any means....but it would make some really good filler for a cityscape.
Ronny Wolf
Well, junior elf, it is meant to be simple and cheap. There is much room for improvement on this building, but as sillyface mentioned, it is the very basic box building. The article itself is well written and has good pictures to illustrate the points made in the text.
cjn003
i had a simular idea to do quick gaming board scenery. What i came up with was to do the same but make 4 or so of the same peice, cutting sections away and sticking them layer on layer so that previous layers show through. Just to get a bit of depth. If you get what i meen. But that would be 4 times the price of what yours took to make. Simple, cheep, quick and reasonably good looking need a least a nine.
