Article: Polishing instead of Painting metal (ie "Real Metal")
Grumb
used to be a Freak
Manu;
Thanks for sharing this with us, and don't worry, your English is just fine!!
Cheers,
Grumb
DragonPaint
This is a technique used in 54mm and 90 mm historical miniatures but this is the first time I see it applied on a 30mm miniature.
The results are really good, thank you, I'll try it!
sulaco
Great article. A question though. How do you (did you) get colours other than silvery metal (such as the gold areas of the sample mini)?
undergroundtoni
instead of using matchsticks u can get hold of a fine metal scribber (used in rubbing/etching foils) from your craft shop...works well for instant shine. Great tip on the Tamiya clear color. I too am not happy with just plain oil washes :)
foetus
Thanks for a great article. I do have one question though. Does the polished effect dullen quickly as the metal oxidises? Guess I'll try it to find out.
amenofys
well thinked and well done; the look of your minis using this technique is natural and different to the rest of the people`s
Aschul
You might want to try using very fine sandpaper (400 grit or higher). It seems to be easier on the hands and will still give you that mirror-like shine.
BrotherCaptain
ive done this on 1 models sword, but it has afew scratches. i used this set which has a small attachement to polish with. it works very well and am very pleased tho the scrathes are annoying. 1 thing tho, if paint goes to the edges of the normal metal. then the paint will start pealing, so you will need to secure it with a small amount of varnish
Aditu
I love this technique! For the last polishing you can very well use a piece of suede. This works very well =)
But one question: How du get into the small edges of that griffon. I had big problems polishing such small corners
Jirris
That's pretty awesome. I've seen people use that technique before, but it's never looked that good. I see polish makes all the difference.
