Article: Trick to realise easy NMM
gremlare
Interesting idea.
Simple.
Effective.
I think finding the right shades of colour to suit the photo's shades is the only issue here. Maybe illaberate on that?
it has been mentioned before but i have never seen it illustrated so perfectly. this is the part of the technique i really struggle with. thanks
Modo
I have had the exact same idea! I am glad to see you got the idea too, because I would have been too lazy to write a tutorial ;)
Grumb
used to be a Freak
One of the shortest, most useful articles on CMON. Great idea, seems like we all should have thought of this sooner.... ;)
Cheers,
Grumb
Trevor
Brushlicker and Freak!
Yes Vince, it works on plastics, you can undercoat them black and shine a bright light on it and it works the same.
ansquer
Yes kronik, of course. But with this fig I dont use it for GoldNMM it's correcting with http://www.coolminiornot.com/84747
kowlown
Le sujet est sur le NMM je sais, mais j'en profite pr te faire une critique tony ;)
Ton idée(pas nvelle mais tu l'as trouvée seul dc c génial)est excellente mais pourquoi n'appliques tu pas cette logique imparable à l'ensemble de ta fig?
Je m'appuie sur tes deux fotos pr dire que sur la peau, tes eclaircissements ne se trouvent pas là où ils le sont sur la fig brute ;)
Non, ce n'est pas ça qui te coute le point ;)
-1: et comment tu fais sur une fig plastique qui absorbe aux 3/4 au moins la lumière... ou mieux, sur une fig métal+plastique+green stuff (ou milliput encore pire lol) ?
Si tu trouves une parade à ma critique, je renote en 10 ça marche? :)
Michael "PROF" Kow-lown :)
kowlown
ansquer
You can do the same with a plastic mini... a first you undercoat your mini with black ... You have approymatly the same result (et Toc!) :)
