Black Skin ?
Dark Seraphim
Hey, I\'m currently painting a mini where his skin is black... but how far do I highlight ? I\'ve highlighted about 5 times with a mix of Chaos Black and Fortress Grey to a dark grey, but I\'m wondering if it\'s enough... or if I should go brighter...
But brigher might make it look not so black anymore... :(
Help!
green stuff
I\'m quite surpised you\'re using grey. Are you painting a drow?
For more natural tones, have a read here :
http://www.coolminiornot.com/article/aid/310
Dark Seraphim
Sort of ;) Elf family yes, hence the grey.. I\'ll check out that article :D Thanks GS
?EDIT: Good article, miss a bit of mini examples.. but anyways I didn\'t mean black as latino, I mean black as drow, sorry for the confusion :D
Anyone got some other thoughts
Use a combination of Dark Brown, Purple & Grey.
YOu\'ll have to work out the ratios to suit yourself. I\'d suggest a test piece of Plasticard with both White & Black primer to see what you are most happy with.
DaN
You got any examples...?
If you\'re worried about it being too highlighted, shove some black wash over it :)
COLOUR-wise that\'s up to you, but with doing skin it depends how you want it to turn out - if you want the skin to look leathery then keep the colours earthy and don\'t worry so much about streaks or brushmarks - they add to the effect.
But if you want the skin smooth and silken, then blend blend blend!
Dark Seraphim
smooth and silky, and it worked, I just kept going adding a bit more fortress grey to my mix and highlighting, till I hit the point where you can see the muscles but still see it as black skin :D
