Blackadder's Attempt To Build a Lucius Patten Imperator Titan 'Invictus'
Blackadder
Main Weapon Yoke:
This turned out much better than I hoped it could. I'm basing it on the most ephemeral of images and I had only a smidgen of the overall detail.
https://i.imgur.com/hS1DBXM.jpg
Tomorrow I hope to have it mounted beneath the superstructure decking.
https://i.imgur.com/fb9vjPn.jpg
Once mounted I'll see how it melds with the overall plan but for now it sure looks like it means business. :D
Meph
Cat-herder Extraordinaire
Colossal and imposing indeed, I couldn't have said it any better myself.
Blackadder
Thanks for the replies,
Requests Honored:
I received a few requests for more information and photos so here's a different view of the same stage of the build.
https://i.imgur.com/jJyiv0g.jpg
The lollipop shaped appendages jutting from both sides of the model will eventually be the main weapons yoke. It is a torsion box assembly built up layers of styrene 2 ft X 4 ft Florescent light lens $14 bucks a pop at the local HomeDepot. I am using this material extensively throughout this model mainly because it is much cheaper than Hobby Store styrene and is a great weight saving building material.
https://i.imgur.com/L894Zio.jpg
I commandeered the Master Bedroom in my home for a Den/Workshop/TV/computer room as it was the second biggest room in the house and all we did was sleep in it; ahem......
https://i.imgur.com/jTByLCd.jpg
Finally it's my work cubical that is constantly being messed up. For some unknown reason I cannot keep it orderly and I hate wasting precious building time cleaning and vacuuming styrene dust. The above rear view shows I've don precious little to the interior decking and have used partially built subassemblies to buttress up the deck to take these images.
Blackadder
The following errors occurred with your submission
*** Forbidden. Message seems to be spam. ***
Can't we fix this?
Requests Honored:
Finally it's my work cubical that is constantly being messed up. For some unknown reason I cannot keep it orderly and I hate wasting precious building time cleaning and vacuuming styrene dust. The above rear view shows I've done precious little to the interior decking and have used partially built subassemblies to buttress up the deck to take these images.
Now with the yoke firmly in place I can address building the interior decks of which I believe there will be five including a railed walk around exterior veranda so Belisarius Cawl can watch the battle from above the fray. These interior decks will be in addition to the Cathedral/fortress superstructure so there will be plenty of room for accommodations of the Officers of the Church.
Meph
Crickey, you do have the most forgiving (or subjugated) wife, to make your mancave in the master bedroom. And I do hope you wear a dust mask in that styrene-infused atmosphere.
Blackadder
Unbounded Mania
My mania is boundless once I fixate on a project. I mistakenly took a shortcut in the initial construction of the chest turrets and have found a better way to reproduce the Gothic windows indicated by the pointer arrow.
https://i.imgur.com/gv0PiSf.jpg
I may or may not rebuild the other four penetrations above the wooden turret spheres but I do like the carrying on of the Gothic theme with styrene strip stock
https://i.imgur.com/DmgbbDG.jpg
Meanwhile I'll complete the two single window sets and prepare them for installation.
https://i.imgur.com/ur17IND.jpg
A couple of skulls and gewgaws and they are ready for installing.
https://i.imgur.com/hpusare.jpg
BTW I've found the author of this titan version on Deviant Art; one Boazzz who has produced a fantastic version of a Emperor Titan that I shall be following (with a Few modifications) for the rest of this build.
https://i.imgur.com/50SkSIl.jpg
A tip of my hat to Mr Boazzz for his monumental inspiration.
Blackadder
I Gotta Learn To Work Faster:
Wow, two days in the making and I'll wager no one will ever notice them when this thing is complete.
https://i.imgur.com/HeMGAha.jpg
That is until the stained glass windows are lit up.
https://i.imgur.com/J4WBhAR.jpg
But seriously I've got to make about forty of these things in various shapes and sizes and I need to get an assembly line going once the basic castle architecture is complete.
These two were just a test run to get an idea of the feasibility.
Blackadder
Gack! I misspelled his sobriquet! It's Joazzz not Boazzz. Take a look at his breathtaking 3D renderings on 'DA' and 'Facepunch'
Here's two more examples of his work.
https://i.imgur.com/kiC4SD9.jpg
I heightened the contrast on the image below to accent the detail.
https://i.imgur.com/C1iQg0D.jpg
With these two shots I can pretty much extrapolate what needs be fabricated. They are so much better than that which I have been working from up 'til now.
Blackadder
Play Time:
All work and no play makes Jack a dull boy. I got a hankering to do some detail so finding and modifying an Imperial Eagle I found on google and tracing it on a sheet of styrene is where I am right now. I intend to make half a dozen of these and some into a bas relief but first I'm starting with a sheet of 0,020 styrene for a durable pattern.
https://i.imgur.com/EQjvwt1.jpg
Meph
That eagle looks excellent. And, wow, that 3D artwork really conveys the size of that superstructure. That's quite the cathedral you'll have to build, but I'm also sure the end result will be mind-boggling.
Meph
A well-executed richness in detail is never futile. just look at Art Nouveau or Art Deco. Even Gothic architecture was never skimpy on the detail.
Torn blue sky
This thing's picking up pace for sure. I still maintain the stance that you're a madman for undertaking a project of this magnitude, but I have to tip my hat and amend it to "highly inspired and inspirational madman".
Blackadder
I've posted on this forum for close to ten years and never been so irritated with a forum policy as I am now. Half a dozen times I have attempted to post on my own thread only to be abused in the most unseemly and chevalier manner. YOU HAVE CHANGED THE RULE OF POSTING IN WHAT I consider a most annoying format and therefore I have removed my upload link from your forum.
Best of luck in the future,
Blackadder
