Blackadder's 'Crown' Experiment
I love 'Eureka' moments, one came to me two nights back at 3:00 AM where for the few previous days I had been mulling how to produce the drive/idler wheels for the tracks. (The Blackadder has very little to occupy his mind these days.) anyway even though I have an even better way, I'll share this eureka moment with you as it is a more general way to make tank road tires.
BTW for those unfamiliar with "Eureka Moment" I enclose the following link:
https://www.google.com/search?q=app...sm=122&ie=UTF-8#q=archimedes+crown+experiment
I hate repetition and the thought of making 40 round tires with axles to make 16 bogie wheels and 4 drive wheel frustrates me and sends me into a state that inactivates me. Rather than wallow in my doldrums I usually just switch to another project which is better for my mental health. Therefor 5 years ago when stymied by the problem, I built Lucie the Warhound (and numerous other projects as well) instead.
So my eureka solution was this, rather than trying to cut round road wheelsof the proper thickness or sandwiching a half dozen or so thin disks together I took thin strips of styrene of proper width (in this case 1/4 inch) and wrapped it around the largest diameter styrene tube in my inventory 1/2 inch which coincidentally was just about the size of the axle needed.
Here we see the first of the eight road tires required already completed:
http://i.imgur.com/kjkte9R.jpg
I'll demonstrate how to make the next one;
Measuring the proper axle spacing I glued the end of the 0,25 MM styrene strip square on the 1/2 inch styrene tube, then when sufficiently dry I filed the end to a fine taper so a lump won't form when I wrap the strip around the axle.
http://i.imgur.com/FxfJVxP.jpg
When the strip is completely wrapped around I insured the wrapping was squared and tight and glued the free end to the wrap. I the proceeded to apply thinset styrene glue to the edges of the entire wrap and allowed to dry.
http://i.imgur.com/v3bSz1e.jpg
I used the milled jaws of the vernier calipers shown to true the wrap edges before applying the glue. (Engineers cringe)
Since the tires will be thicker than the one strip of styrene will achieve I wrapped a second around the first in the same manner. Now that the tire diameter is significantly larger than the 1/2 inch axle it was safe to use a thicker wrap, in this case I used 0,4 MM strip styrene.
http://i.imgur.com/w2F2RXF.jpg
Here we see the tire finished wrap with the vernier calipers in place to compress any spiraling edges so the strips aren't telescoped.
Next post please.
