can you use vallejo game color in an airbrush?
nerdfest09
Hi guys, I'm looking to start a salamander army and I'm looking for a green paint for my airbrush to base the vehicles and perhaps troops? I can't see a vallejo model air paint that would match a salamander scheme, but in the game color series ther's a scorpy green that looks good, could it potentially be used in the airbrush? I only have a basic set up compressor and pasche single action gun, can someone help me find a green paint to use?
cheers
Nerdfest09
cheers
Nerdfest09
If you thin it properly it should be no different to any other Acrylic paint.
I'd suggest though for a brighter green use a Grey primer (automotive primer) rather than GW spray paints.
DarkStar
In case two wasn't enough I'll add a third voice saying it's fine, I do it all the time. Clean your needle very frequently as Game Color has a weird "satiny vinyl" type of buildup that can occur (with certain colors more than others) and clog pretty quickly. Keep a little makeup sponge nearby and some alcohol and just keep the needle clear of buildup as you spray the stuff and you can go all day with it. Thins just fine with only water.
gohkm
... Keep a little makeup sponge nearby and some alcohol and just keep the needle clear of buildup as you spray the stuff and you can go all day with it. Thins just fine with only water.
With regards to this, is it fine to blast acetone through the airbrush or soak the needle in acetone to loosen and dissolve any paint accumulation?
armornv
Soaking the needle is fine, I've done that before myself. Even though acetone dries/evaporates quickly, I'm not sure how it would affect any rubber o-ring seals inside the brush itself. Never tried it. Usually all it takes for me is to blow a cup or two of windex through to clean the brush out.
DarkStar
Never sprayed Acetone through anything personally so I can't give you any anecdotal advice on that. I use alcohol to clean my airbrushes and once in a great while I'll really soak it and scrub it with some Lacquer thinner, which I don't spray out afterwords as that stuff is too nasty to bother with for all but the most caked on paint.
I hate to recommend anyone using lacquer thinner though that stuff is just foul. But it's effective. I've taken apart my brush, removed all the little parts that don't need to be cleaned and soaked it in the devil's brew overnight a few times. Probably not too good for it but I've never had it destroy a brush or anything. Next time I really have to clean my brush down I'm planning on using this cleaner I've found that I use to strip paint with called "Totally Awesome" (yes, really that's the name). It works great for stripping paint from just about anything so I'm thinking of giving it a shot of cleaning my brush when it gets bad. But, that will be some time coming as I just got a brand new brush so I won't need to experiment with that for some time.
*You know come to think of it in my early 20's I had a job at an optical lens lab and I use to strip and clean our tools in big vats of acetone overnight. I'd leave em in there with a lid and come back in the morning and rinse them out and they'd be fine. But here's the reason I posted this, I left a rubber glove in the vat one night just to see what would happen and in the morning the acetone had eaten it, so yeah as mentioned above, maybe not the best thing for any rubber gaskets and seals in your device.
RuneBrush
When I empty my airbrush (when I finish a session or change colours) I crank the pressure up, rinse through with clean water, then a squirt of Badger Airbrush Cleaner (which is alcohol based) and then another load of clean water. Generally this is enough but it's not uncommon to have to dismantle the airbrush to clean any blobs of paint. Again the Badger Airbrush Cleaner will shift most debris and dries out rapidly. I always make sure that I've used clean water to get rid of any remaining cleaner though.
wixxer
I use a 0,2 mm nozzle (Evolution Line), properly diluted it works, though it clots once in a while. Do not forget to clean your airbrush properly!
nerdfest09
Thanks for the help so far guys! very helpful! so if i'm reading correctly, i can use the game color acrylic paint in my airbrush and dilute with only water ( I imagine vallejo acrylic thinner would be good? as i have some) and clean my ab with acetone? is that the nail polish remover that women use? do you know the ratio of game color thinners i should be looking at?
on a side note are there any other companies that make airbrush paints? or is vellejo the best ones out there? just trying to get as much info before i start.
thanks again everyone
Nerdfest09
RuneBrush
That should be fine.
It is, but be aware that some of the better quality nail polish remover will contain extra crap for strengthening nails as neat acetone is quite evil. I'd personally not want to shoot this through my airbrush. The cheap stuff should be ok though. Also run water through to wash out any residue as the residue could mess up any paint you've already sprayed.
There isn't a ratio to use because all paints are different viscosity, you can even pick up two pots of the same colour that are different! I thin my paint to the consistency of semi-skimmed milk.
