casting
cybersquig
Dangerous when wet
I\'d love to make casts of some components I\'ve sculpted so that I can make many accurate copies of them. Having said that I have absolutely no idea how to begin - is there somewhere that has a comprehensive explanation of such things? If not, any advice on the potential options open to me?
PegaZus
Stealth Freak
I think Hirst Arts may be the gold standard of casting (or at least, mold making) in many people\'s opinion.
Here\'s his mold making page that would probably be a good place to start.
Try a search, lots of previous threads on various casting issues with info that\'ll help. Here\'s one:
http://www.coolminiornot.com/forums/viewthread.php?tid=28412
what meduim are you wanting to produce?
Press cast in milliput/GS/sculpy?
Poured resin cast?
Poured white metal cast?
How many products are you wanting to pull from the molds? At what kind of production rate?
http://www.smooth-on.com/
cybersquig
Dangerous when wet
all good questions airhead, thanks.
to clarify,
I\'m quite happily press moulding components as I need them, but I\'d like to be able to make a mould of some greens that I can use maybe a few hundred times as I need to, with better accuracy. Then I can make my own dollies quickly, in various states of dress and undress, which\'ll make the whole scratch building process easier. Plus some people have asked me if I have the ability to cast some of my sculpting work for them to have a copy - I\'d be happy to oblige if I just knew how to do it. So to answer the question about production rate, I\'m not fussed really, just something quick, easy, reliable, accurate and without an extortionate setup cost. I realise some of those things may well be mutually exclusive. Oh, and if it only required materials and equipment I could keep in my caravan then all the better!
Thanks again,
James
I use the smooth-on products. Quart of mold making ureathane rubber and a quart of casting (white) resin. Some leggos to make mold boxes and some sculpy to seal it. All in a box about the size of a shoebox.
FYI, All of the products have a shelf life once you open them.
See the link above. There\'s some good articles and also the Hirst Arts website linke earlier.
cybersquig
Dangerous when wet
thanks guys, that\'s really great. I still don\'t have time, but when I do I\'ll scour the websites you\'ve all recommended, I\'m sure they\'ll clarify things for me. Thanks so much!
