I lit a fire under my ass the other day, and in turn got a ton of work done since the last update.
First you can see a lot of painting. I did the upper cote of paint on the negative space between the beams. On one I used bone mixed with mustard, on the other bone mixed with sage green. After those were dried, I did a light wash with dark brown to dirty everything up.
I then painted the beams raw umber, not really making it a consistant cote. It soundes weird to not paint an even cote on it, but when all is said and done, it will look more natural if there are variations in the color of the wood. 2nd step on the beams is a light drybrushing of light grey. This ages the wood, and brings out the textures. Let me just say that it takes forever to paint the beams, since every one of them has 3 exposed sides that all have to be painted without painting \"out of the lines\". On the plus side, if I do get the dark brown outside of where it should be, if I water it sown right away, it basically turns into the brown wash that I\'m already using.
What else. Well I built up the terrain that would be the ground, using thin shavings of pink foam layered on top of itself. I decided a while back that even flat ground realyl isn\'t all that flat and level. So this gives the ground a bumpy look. Unfortunately, it means that any topheavy minis will probably fall over when on it. I sealed it to the board and filled in the gaps with water effects. Did I mention I love this stuff?
I then covered the whole thing in a cote of green paint, brushing the high points in browns. This is so that when it is flocked, if any wears off, it will be green and brown, and not pink in the bare spots.
Lastly, I added some foam boulders, and gravel for the pathways. These buildings won\'t be on te main streets, so I went with dirt paths rather than cobblestone. They are made up of 3 different coarse sands, from rough, to medium, to fine. I start with the coarse, then work my way up to fine. These will be painted too to give a more uniform color, with highlights.
This is coming a long nicely. Up next I\'ll paint the paths, and flock and detail between the buildings. Once that is done, I can glue the houses on, and start the woodwork for platforms and stairs, this one will have lots of them.
