Darrell Hindley
I recently put together some simple (but effective?) conversions to create more varied command bases for my Early Byzantines. Since the days of seeing Barry Hilton's Flodden bases and David Imrie's wonderfully well c0nstructed Late Roman era units back in the early 2000's I have tried to present by bases as small vignettes where possible.
For more information on which packs I used from the Aventine Early Byzantine range, what composition I went for and for many more pictures please hop on over to my Just Add Water blog here:
http://justaddwater-bedford.blogspot.com/2022/10/converted-early-byzantine-command-bases.html
Command Base 1:
A simple repositioning of the arm was all that was needed to make the advancing Skutatoi/Kontaratoi model into an advancing standard bearer.
The Finished Article:
Command Base 2:
The standard on the right was carefully clipped off, filed down and replaced with part of a wire spear. The Draco was easily glued into place.
Cheers
Command Base 1:
Command Base 2:
Cheers
