another trick when using that paper-cutting knife (i use those knifes on foamcore to make building models for school) is to keep the knife almost flat against the surface, this will give you a longer and gentler cutting edge. and you need to apply almost no pressure at all, i\'ve found that when you are through the first layer of paper, the knife will draw itself in automatically as long as you keep the blade flat enough.
