Da Bears
TheRedGod
Reposting this due to the first time the thread was hijacked........
Can a skinchanger deploy the bear when its unit activates, then get moved to a new unactivated unit with Regroup and Reform, and deploy the bear again when that unit activates? If so, what exactly would happen?
Bear - "If this unit was selected, when its bonded skinchanger activates, deploy it engaged in the front or flank of 1 enemy engaging its skinchanger. it then performs 1 melee attack action. remove this unit at the end of the round."
- would there be 2 bears on the field now?
- would the bear already deployed be deployed again?
- nothing happens because the bear cant be deployed again ?
CMON Michael Shinall
Administrator
Your answer is the third one you posted.
The Bear was selected, it was deployed. Even if the Skinchanger is moved and re-Activated, the Bear itself cannot re-deploy itself (as nothing is allowing it to do so) and it has already been deployed.
This however can be a candidate for adding to the FAQ, due to its specific interaction.
