Dark Angels Chapter Master
ScottRadom
Shogun of Saskatchewan
Looks to me like it's parts of the wings. You should PM Semi, I'm sure he'll answer your questions!
nels0nmac
In the case you are highlighting I think the photo etching is the stem of the wing which Semi has used to sculpt greenstuff onto so that what would be a fragile feather is a lot stronger.
Photoetching ( also known as brass etching / acid etch ) is a process used to create fine patterns or filigree work in metal. Forgeworld use it to create decorative plates for the marine chapters. Link to FW page :-http://www.forgeworld.co.uk/acatalog/ETCHED_BRASS.html
It can be quite expensive to create custom etchings. If you want to know how to create them then LMK
