ok, so here is Angelos
if that doesn\'t work, then just look here:
http://img.photobucket.com/albums/v311/fire-dragon-studios/mainthingy.jpg
basically it is the force commander from the new plastic kit.
Alterations as follows:
1) Used the space marine tank commander from rhino et al sprue, then sculpted some thinning hair onto the back.
2) Fiddled about with marine arms from the tank sprue (arms that would fire a stormbolter) and the \"pointing\" arm from the comander sprue, attached hands that would usually hold chainswords, drilled through and used some rod to make the hammer haft, then sculpted in some wrist area.
3) Shaved down the dwarf hammer from the regiment box and drilled a hole through it and attached it to the hammer haft, the sculpted it flat, then sculpted on the weird line parts then attached shave down skulls off of the veteran plastic shoulders in the command unit box, then attached a purity seal, then sculpted the bit on the bottom of the hammer haft (this is yet to be shaved down as it appears to be a kind of 3d rhombus shape in the game.
4) Filled in the shoulder joints and sorted out the joint between thorax and pelvis.
5) Cut up part of the eagle banner top to make the wings on the left leg, then cut down the scroll and added that.
6) also sculpted onto a terminator honour piece to make the part on the chest.
That\'s more or less it, I\'ve worked from some screenshots and memory and i have since noticed the hammer in the game has a part in the top missing but oh well, artistic licence :duh:?
I\'m painting it up soon! Hope people like it.
RUfio xx
