Track this type of annoyng bugs is my work
Most of the time you have to check two things: heat and power
heat: check if the computer has all the opening free, if you have the rear of the PC near a wall or under your desk check that the air from the power supply or the other fans can freely flow away. If you have something that interrupt the air flow the temperature inside the case can be too high and your system shut down.
Open your computer and check if all the fans (system, cpu, graphic card) are working and that your computer is clean, someting the dust can block the regular flow of the air. Check also that your cables are secured all toghether and away from the fans.
Of everything is ok, touch your power supply, if the power supply is too hot probably you have added some new device that drain too much power and you need a bigger power supply (more Watt)
If you can find another power supply try to change it and check if the problem is gone.
Hope it helps and sorry for the bad english, I\'m a bit in hurry to check it
