I\'ve found that most people that have been painting a little while have had this happen to them. You\'ve got that new masterpiece done and you go to spray it with your preferred type of dulling/matt spray and as your spraying the paint starts drying in the air and instead of a nice clear finish you get a white speckled or worse yet white spray of death that coats the figure in a dull white coat.
While I\'ve never been able to recover from a complete white spray I have found a way to fix the speckled type. If you use one of the brush on type gloss coats over the affected area it will remove the speckles. And then you can use a brush on dull coat to cover the gloss.
I\'ve tried many things that don\'t work to remove a full white spray. One thing for certain is don\'t use more dull coat. It just makes the problem worse. Same thing with removing it...if it\'ll take off the spray it will take off the paint. So while this will fix a slight dusting, I still haven\'t found a way to completely recover from the white spray.
