Dwaft Berseker
cheelfy
welcome aboard first. Your mini looks nice for a first painting. I have some crits though: on the top part of the right axe, you forgot to put off a mould line; looks like you painted the axes by mixing some grey paint to metallic paint, you did, you have to know that when you mix "normal" paints to metallics, you musn't put too much of the non metallic paint in the mix if you want to keep the shine of your metal for it to look realistic. Some areas of the mini aren't shaded (gold, hair, apron), don't be afraid to shade, try to use washes, it'll help you shading more smoothly. The wood of the axes doesn't look very realistic, you could paint it a bit like the beard and then shade it a bit more and re-highlight using and bone colour in the mix. The last thing for me is the base, looks a bit simple and I think the sides of the base haven't been painted, it's correct for gaming but you can try new things like putting grass, trees, leaves, water...anything you want on your bases.
I hope all those crits will help you improving for the net mini, don't forget to check minis all over this site, you'll find lots of ideas for everything you want to do. You can also start a wip thread if you want, you'll show your process on the minis and you'll get feedbacks and advises from lots of people.
count zero99uk
Thanks for the comments. Im not sure on teh best way of shading gold. The goblin head i did in brass then did a wash of very watered down smoke ink, then highlighted with gold. That seemed to work well, but i did this after the hair clips (not that id say a dwarf wore hair clips to his face).
The axes i wasnt happy with the hafts either, i think i started rushing a bit towards the end if im honest. The mini just started of as a practice in skin tones. As for the axe heads, its a base of dark grey with a dry brush of metalic silver over. However now ive done some reading I think NMM may have been better, and i think on the next mini i do i will attempt that.
Thanks again for your comments
Regards
Brian.
supervike
Great first post! You're getting the basics down. Just remember to strive for a clean looking finish. Drybrushing will end up with a chalky finish, but you can still use the technique provided you do so sparingly, and use a wash or two to smooth it out.
There's a ton of tutorials for you to use here on the site, from flesh tones, to metallics...so I'll just mention that you should check those out.
When taking a picture of the mini, I think it works more to your advantage to get a 'eye level' photo, instead of the 'top down' shot you seem to have going on here. It will give a better representation of what the mini actually looks like.
Keep at it. Just paint one mini at a time.
