E bay: how do you tell a recast/fake/counterfeit from an original
hubbabubba
......And is there that much difference.?
Well what do you have to say?
I\'ve bought stuff off e bay in the past that was most deffinately recast by amateurs. the quality sucked and I was pissed off. How can we avoid this?
If you\'re army building and buying grunts, maybe you don\'r really care.
Point is, from the shear amount of stuff out there for sale, how much fake stuff is there and what kind of difference in quality are we talking about?
Oh do share. I feel so all alone.....:evil:
If the seller is selling it over and over, and they are selling it cheap.. its useually a recast. Especially if its loose metal and has no packageing. If you get a casting, check it out. if its got double sets of mold lines.. useually a good sign its a recast.
No Such Agency
... unless it\'s a mini where the master had different mold lines than the production model. It\'s not uncommon... annoyingly!
squidders
Thanks Matty - that\'s a really good link.
I buy a lot of old minis from ebay and have been stung before. I pretty much know what to look out for now but still, i\'m not as careful as I guess I could be when demanding better photos etc.
Ritual
Yes, I\'ve had double sets of mold lines on quite many minis. And I\'ve bought them from stores carrying the miniature lines in question, so they are not recasts.
hubbabubba
Thanks for the link Matty.
In summary then, if in doubt, especially if it\'s a loose piece, ask for a scan.....
What about all those people out there selling loose plastic sprues, and separate bits, I guess some are spares, and some are maybe off the back of a lorry so to speak, but I guess again that the majority are recasting. Is there much difference inthe quality of recast plastics?
EArkham
Necromancer
The CollectingCitadelMiniatures yahoo group has some info on recasts: CCM Recast FAQ.
May have to be a member to see that file, dunno. I\'ll cut and paste the pertinent parts in case:
How to detect a recast?
Unfortunately, it can be argued that no-one except for an official from GW could state without a shred of reasonable doubt that a figure is recast or not, and to be perfectly honest, I highly doubt if one of them would know either. The problem is that, these days, if someone is prepared to pay a professional mould maker to prepare the mould and to have the figures cast professionally in the right quality of metal, it would almost be impossible to tell them from the originals. But you have to ask yourself why someone would bother to do that. How prevalent are counterfeits, for example on eBay? Is it cost effective to do this? Realistically, recasting would not be an economic proposition unless you did it at very low cost and quality or in noticeably high volumes as the cost of making quality moulds and using quality metal would mean unit costs were at least as high as the current retail price. The chances of encountering a recast figure are probably quite small.
So, spotting a recast is not as easy as you or I might wish – despite the warnings issued by a certain major games corporation! Some recasting might seem pretty obvious - the figures have very poor detail, the colour is wrong, there are multiple mould lines and they have large lumps of sprue attached from where they were cast. Of course, you might not be able to prove that such a figure is a recast, but hey – would you even bother buying it in the first place if it looked that bad?
Some alleged signs of a recast figure are as follows:
- The figure has multiple mould lines
- A seller sells multiples of an apparently rare figure
- The colour of the metal is wrong
- The figure is cast in the “wrong” metal
- Level of sharpness and detail/less than crisp casting
- The tabs of the figure are “wrong”
- The figure is a little smaller than other, supposedly identical, ones I’ve seen
- The figure looks a little different to other, supposedly identical, ones I’ve seen
- The figure doesn’t “sound” or “feel” right
Let’s examine these in turn.
…or even triple mould lines have been cited as the most likely evidence of a figure being a recast. Not so. Many group members have received figures direct from GW (loose and in blister) displaying double or even triple mould lines. Double mould lines are not necessarily the sign of a recast. All genuine GW figures have the potential for double mould lines. This is why:
The old manufacturing process (green => master mould, master mould => master tins, master tins => production mould) means there is a chance of double mould lines if the master tins weren\'t cleaned up properly. When a figure is sculpted, a single \'master mould\' is made from it. This master mould is cast several times (maybe up to 20, depending on the size of the figure). These \'master figures\' are then used to make
a \'production mould\', from which new figures are cast and blister-packed. The master figures are generally kept so that new production moulds can be made when the old ones are worn out.
The step in the middle of this process is where the double mould lines can originate. If the master castings are not carefully cleaned of all casting lines before being used to make a production mould, the production figures are very likely to have double mould lines, as it is highly unlikely that even the best mouldsman would position every
one identically in the mould. Interestingly, this also means that castings of the same figure could easily have mould lines in slightly different positions.
Take a look at some of your castings sometime, especially older, pre-pewter stuff. You\'ll see that double mould lines are not uncommon, and certainly don\'t indicate forgeries.
Selling multiples of rarer figures is not a good guide either. Rarity is relative and while some figures seem rare because they don\'t turn up on eBay every week, that doesn\'t mean there are not hundreds around. For example, many members of the CCM group have bought bulk lots from ex-GW staff members that have included multiples of supposedly rare items.
This ruling doesn’t just apply to rare figures either. For example GW mail order used to have \"bargain bucket sales.\" It was quite possible to end up with multiples of the same, relatively common, figure.
It is possible to cite other seemingly suspicious buying and selling habits. For example, the observation that someone buys a relatively rare figure only to start selling it in multiples several weeks later might at first seem suspicious. Could it simply be that the seller was formally amassing figures for a particular project only to abandon it later for any number of reasons? The truth is it’s normally quite a time-consuming and involved proves to build up a case for someone being a recaster based on their buying and selling habits – even by GW’s admission.
The fact is that the genuine castings from GW are not universally the same in appearance. The same miniatures, new in blister, can range from a dull darkish pewter shade through to a very bright almost silver shade and just about everything in between. Some miniatures, again new in blister, can have brownish or yellowish tints and even slight pitting on the surface. And figures cast in USA can look different to the same figure cast in the UK. So colour is not a good guide at all.
Further, if someone has gone to the trouble of doing a good job of stripping off old paint they have also, intentionally or not, cleaned up some of the oxidation which appears on the surface of an older casting, so quite an old mini can look almost new. Also, an “overly shiny” figure as seen in a photograph could simply be the result of bright light – obvious I know, but it’s surprising how off-putting a shiny figure can seem in a photograph.
One thing to bear in mind is that Games Workshop frequently have and do recast their own miniatures – these can be described as “official” recasts. This means for example that a figure that might have been originally released in lead alloy during the 1980’s could have later been recast in white metal by GW and sold via stores or mail order. There have even been accounts of preslotta figures being recast by GW in white metal. So you may well have a recast figure, but it would have been recast by GW. Purists might have a problem with this; whether you do or not is a personal issue.
Also, parts that were previously commonly available in plastic might also have been recast by GW as metal parts. For example, before the new plastics came along there was a period where the plastic moulds for things like Imperial Guard arms had died. For a very short time the bodies were still available through mail order and they came with metal cast arms which were just the plastics recast in metal.
The exception to the above of course would be to receive a figure from a current range of figures that has been cast in old lead alloy. GW haven’t used lead alloy to cast figures for many years, so if you receive a new figure cast in lead alloy then it will be an “unofficial” recast.
Bear in mind that a badly cast figure could well be a miscast rather than a recast. What’s the difference? Well, quality control at the factory has varied over time and in different countries. In general, quality control was worse historically, and a few badly cast models would slip out (this is even mentioned in the early catalogues, compendia, journals). Poor quality control can lead to missing bits, badly cast bits and tarnished metal. It is not that unusual for a mint figure to have a casting flaw of a minor nature. Also remember that flashing and bits of metal left over from the casting process are perfectly normal and quite common.
If you cast something you will lose some of the quality of the original green. Figures cast from that mould will have lost a bit of quality compared to the original green; if that figure is then used to make more moulds it will lose even more quality. This can be seen by placing it next to the original: detail such as facial features, chainmail, fur, wood grains etc are areas that might look “shallower” i.e. not as deep or clear cut as they maybe should.
Tabs can vary across identical figures, with some bearing names and others being blank. Also, particularly for older figures, large pieces of metal can be left on the tabs or under the bases of preslotta figures simply as a result of the casting process.
Compare your figure with an identical figure (hopefully came out of packet). If yours is smaller, and also displays bad casting etc then it is possibly recast but not necessarily – judging the sizes of two identical figures can be quite subjective. Also, new moulds could be cast from figures multiple times leading to a reduction in figure size.
The preslotta Citadel figures produced and distributed by the Canadian miniatures company RAFM used a different alloy mix and they can be much shinier. Usually RAFM figures are good castings, though. Note that RAFM/Citadel figures are genuine legally produced figures made from Citadel molds. Also, Ral Partha shared many figures with Citadel, with the resulting figures often being very similar but with minor differences.
Some collectors believe that recasts have a certain “feel” and that they make a certain sound when dropped onto a hard surface that is different from a genuine figure. This is especially true of the older figures. This is highly subjective of course, and very difficult to quantify.
In conclusion: provenance – your best bet.
So, all in all it would appear that identifying a genuinely “unofficial” recast figure is pretty difficult. As has already been established, figures that display pretty major defects shouldn’t be purchased in the first place, or if they arrive as part of a large batch then you should be perfectly within your rights to ask for a refund.
Provenance is a good tool in the fight against recasts. Provenance is defined as “proof of authenticity or of past ownership.” Documented evidence of provenance for a figure can help to establish that it is not a forgery or a reproduction. Your most reliable test is the reputation of the trader and the provenance they can provide - but be prepared for some reluctance to disclose names as if someone has stuff from a former or present GW staff member that is not meant to be in the public domain, they are likely to want to protect their source from any comeback from GW.
At the end of the day, you are relying on the reputation of the seller. If in doubt it is not unreasonable to ask for the provenance of the figures - most good sellers will understand if you want to know and will happily provide you with any information they have. And if you are not happy with the provenance don\'t buy. And if you have already bought and have a reason to be concerned, for example because the quality is really bad, you could go back to the seller and ask for a refund. Many sellers will refund if you have a serious concern as they value their reputation and do not, in any way, wish to be thought to be trading in recast items.
Yessh, that\'s a lot of text, but hopefully should be helpful. :)
-Kep
The main problem with buying from Ebay is that there is definitly a sense of \'Caveat Emptor\' .
I know that I\'ve ended up buying something on Ebay that turned out to be a recast of a long out of production piece, thinking it was genuine.
I\'ve also bought something from a shop, in good faith, which I now suspect to be a recast. However I\'ve no way of proving it as not only has the shop changed hands but the original sculptor has dropped well below the Radar and seemingly given up sculpting.
Something you need to be aware of for Ebay is that some countries have far differring legislation regarding Copyrights and the duplication of items for Sale. China is one.
The Philipines are also an area where wholesale duplication is an \'industry\' and items from Levi Strauss Denims to copied Smith & Wesson firearms are easily obtainable.
hubbabubba
Ok, Thanks to Earkham for the article, between that and the one Matty posted, I at least feel a little better informed.
Cheers all and happy shoppinglol
