Seems I have to pay more attention to the faces
Thank for your comments Tabithatan, you\'re right... I need comments about my errors so I can paint better next mini
Trevor: thank you for your comments.
About the base.. it\'s just a block of styrofoam shaped with a cutter and glued on the base. Then I have sprayed a thin layer of GW black primer... this melt the styrofoam a bit giving a nice \"rocky\" effect.
I have added a bit of fine gravel around the base gluing it with PVA glue and Vallejo Pumice Stone for the musk/grass.
I have painted the stone using Vallejo Dark Bluegrey 867 and then adding highlights with Dark Blue Grey 904 (yes, same name but different colors), Stone Grey 884 and a bit of Beige 917.
All the highlight was blended without the use of drybrush to have a better control of the shades.
For the musk: Flat Green 968, Olive Green 967 and Lime Green 827.
Paolo
