Ditto
Originally posted by Nekron99
I use a pen too, the Sakura fine line .005 comes in a bunch of colors, and work great for blacklining, pupils, tattoos, cape/robe embellishments, etc.
I hate sounding like Rush Limbah, but I go along with the .005 Sakura pen. Hey, if it\'s good enough for Jen Haley, it\'s good enough for me.
Though I did use a shapened plastic toothpick once.
Oh, and don\'t use white for the eyes. Will make your guys look google-eyed. Use a 50/50 mix of white and bleached bone. Thin VERY carefully, and use a very fine brush.
This is what I\'ve started to do for eyes. It\'s a mix of several styles, actually.
I basecoat the whole face with a flesh tone about two shades darker than my final, usually Dwarf Flesh.
I fill the eye socket with a 50/50 mix of Vallejo Model Color Burnt Sienna and Plaid Walnut varnish. I thin this a little with water or Magic Wash. I also trail this mix down the sides of the nose, just under the nose, the lips and just under the lips. If the cheeks should be defined, then I also put this under the cheekbones.
Use a fine brush to put the thinned white/bleached bone mix on the eyeball. If there\'s a boo-boo, clean it up by painting over with the dark mixture.
Dot the eye with the Micron pen. The dark mix above and below the eye will mask any errors in getting the pupil a little high or low.
Using a Windsor Newton 000 miniature, I put a mix of Dwarf Flesh and Elf Flesh above and below the eye, leaving brown lines around the eye. I also leave a line of brown for the eyebrow.
I use the same paint on the eye ridge, leaving the brow. I touch up the brow if it needs it.
I\'ll add Elf Flesh a little at a time to the dwarf/elf mix and layer up until I get the color I like in the eye area. I\'ll also start layering the other areas of the face.
Dragonsreach has a very good article on painting faces here on CMON. If you look at that, you will have a good idea of what areas of the face need to be left darker than others.
Part of the problem with getting good eyes is just your brush skills. Everything you paint will suffer until you can get this down. Eyes just show this weakness more because they are so delicate, and are one of the first things people look at on a mini.
It takes time and practice to build good brush skills; keep at it and you\'ll get better.
